Question about Breville EW30 Gourmet Non Stick Electric Wok
This is for assembling the Breville Wok lid. This has a built in vent that lets steam escape during cooking. There are 8 pieces not including the glass cover: bolt, metal vent, black O ring, tan round plastic piece, black lid piece (has open/close) on it, spring, clear plastic seal, lid handle.
Order of assembly as follows, starting on inside of glass cover.1. Bolt.2. Metal vent piece sits on top of bolt.3. Black O ring fits snuggly onto of vent piece.Insert what you have assembled against inside of glass cover, bolt poking through topside of glass.4. Add tan plastic piece with 3 prongs going facedown against the glass hole of cover.5. Larger black lid piece goes next. You will need to line up the openings on tan piece and this lid piece so that it sits semi-flush against glass. When complete this piece will turn in place to open/close vent (less than 1/4 turn before stopping).6. Add clear plastic seal to underside of handle.7. Place spring between handle and top of black lid piece and screw together until snug.
Test lid by turning lid piece. It should move back and forth according to the open/close print on top. If no luck, go to step 5 and try again. It is a little tricky, but does work when done correctly.
Posted on Jun 10, 2012
I had the same problem but when the cover came apart the clear plastic seal was attached to the tan plastic piece. It was attached on the 3 prong side. I left it where it was and everything went together as you said. tks
I had the same problem -- my lid assembly bits fell into the curry! The only thing I was not sure of which way to place the metal vent place so I guessed. Everything worked except the knob does not stop either direction but it never did and I think that's how it came unscrewed. I just won't use that feature -- the wok is wonderful and if I want it to vent i can stick in a chopstick or something between the lid and the wok.
Thank you so much for posting the directions. All Breville has that I could find at their website was ordering a new assembly.
Toby Salt spring island
Jul 10, 2014 | Wahl 9307
Apr 02, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
Apr 24, 2011 | Kenmore 24972 Top Load Washer
Jan 14, 2011 | Rival WS60T Non Stick Electric Wok
Nov 01, 2010 | Breville 6-Quart Electric Nonstick Wok
Oct 30, 2009 | Presto 06821 Electric Skillet
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Jun 13, 2009 | Breville EW30 Gourmet Non Stick Electric...
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
3,094 people viewed this question
