Contributor
- Posted on Feb 03, 2011
Re: Hello,
My Creda cookertop ignition system has a...
(1) Get Naval Jelly (Rust dissolver) and apply on the igniter and than see if everything is fine.
(2) Check the connections from the knob to the burner. Probably have a leak. Replace the wire from the knob to the burner.
Thanks. I've circumvented the problem by turning on the knob of the target burner to allow gas flow at close to minimum and simultaneously turn on the good/working burner knob to create spark in all the 4 burners. Then turn off the latter as soon as the target burner is alight. In this way I do not need to resort to a manual or hand held sparking device.
Hope this sharing can help those with this odd problem which problem needs rewiring at the faulty connections of the defective knobs.
