Question about Whirlpool Duet GHW9150P Front Load Washer
What is an F35 code? - Whirlpool Duet GHW9150P Front Load Washer
Posted by misol51 on
william
    New Friend:
  • 91 Answers
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
Posted on Feb 02, 2011
John Wegerbauer
    New Friend:
  • 4 Answers
I had this error a couple of times too. The first time I encountered it I got a "SUDS" error and a few minutes later F35. I replaced the pressure switch and it worked great. I recently had the exact same symptoms. I replaced the pressure switch again, no change. Ordered another switch (in case the first new one was bad) - no luck. Ended up having to replace the master control unit. I now have two of the pressure switches and am selling them on eBay at a substantial discount. Go to: eBay Link
-or-
Go to eBay and search for the part number (W10415587). Mine is listed for $50 or $65 instant buy.
Posted on Sep 13, 2013
Fault code F35 on my washer what does it mean?
The F35 error code indicates an analog pressure sensor error. ... This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem.Jun 3, 2011
SOLVED: F35 error code appears during cycle - Kenmore Elite HE3 ...
https://www.ifixit.com/Answers/View/54204/F35+error+code+appears+during+cycle
See this link and watch the videos
Fault code F35 washer Google Search
Jul 31, 2018 | Washing Machines
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code washing is delayed wil wash half the clothes
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F35
May 18, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Whirlpool Duet GHW9150P Front Load Washer Logo
2,036 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
