Question about Mitsubishi WD-57733 57" HDTV
I have a 60 inch mitsubishi flat screen n i someone shot an bullet thru my tv n i would lik to have a quote on how much would the repairs be?
Posted by brittanyport on
rhodesworks
    Top Expert:
  • 3,157 Answers
Generally speaking, though it may be possible to fix a broken screen, it's not cost effective and you'd be better off replacing the TV.
Posted on Jan 25, 2015
Chi Chu
  • Mitsubishi Master
  • 8,457 Answers
Sorry tv not repairable,the picture screen panel is broken or damages.The tv picture screen panel are 90% important to the tv and it is limited in production by the tv corporations,no where u can buy tv picture screen panel except the tvs corporations themselves.By replacing the tv picture panel,will cost the same as a new tv,by replacing the picture screen panel alone,because of it limited production and important to the tv itself.Sorry this not worth as a whole tv anymore,now tv only as salvages tv for it electronic boards for parts only now.
Posted on Feb 02, 2011
Hi,have a 60 inch plasma lg tv some 6yrs old or so and the picture has gone out but still have sound,any ideas?
screen out of works.
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 08, 2018 | LG Televison & Video
I have a Mitsubishi 60 inch flat screen TV. replaced the lamp. two streaks in the middle of my TV that are black that you can see when the picture is on. about an inch long.How do I get rid of them?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 24, 2015 | Mitsubishi Televison & Video
MITSUBISHI 60 INCH PROJECTION TV WITH LITTLE WHITE DOTS ON SCREEN
You will need the DLP chip replaced. I do not recommend trying this on your own on a Mitsubishi. You need a technician who has extensive Mitsubishi experience to replace that chip(if it is available for your particular model) If the chip is not available for your particular model, it means replacing the light engine.For that cost I would update to a LCD or LED TV & come out ahead.
If you want an idea what it costs to replace the DLP chip (if avail for your unit) contact a local servicer & see what they can quote you over the phone. Be sure you are sitting down.
Considering the age of your unit I would be looking at an LCD or LED flat screen.
Jul 24, 2014 | Mitsubishi Televison & Video
My tv is stuck in the screensaver mode. I have a mitsubishi 60 inch tv
try the soft restart--turn set on with Mitsubishi remote and enter Menu, 1,2,3, enter.
Aug 27, 2012 | Mitsubishi WD-60737 60 in. HDTV
I keep getting a blank blue screen when I turn on my Mitsubishi 60 inch TV and then turns off by itself after about a minute. When I press "pip" on my TV remote I can see a small square screen...
there are 2 tuners in a rear projection tv. maybe the main tuner is faulty or the tuner's associated circuit has problem. if there is no signal these tv are programmed to turn the power off/stand by.
Aug 19, 2011 | Mitsubishi VS-50603 50" Rear Projection...
NEED FRONT SCREEN THAT FITS OVER SCREEN
I'm trying to remove the screen from mine, do you have an owner's manual that shows how?
Jan 12, 2010 | Mitsubishi VS-60707 60" Rear Projection...
Wrong Chemical Cleaner on 60 inch DLP TV
Hi There,
Unfortunately, I think you may be out of luck. If you spray a screen directly you are taking a chance at killing your TV. You're actually pretty lucky that it still works. Some chemicals can eat right through or seep through edges and corners and ruin the life of your TV. I am not sure if Mr Clean contains alcohol, but that is the last thing you want on any screen. I would suggest trying to clean it off with an alcohol free solution for HDTV screens only or calling Mitsubishi immediately and see what they have to say.. Here is a similar product for what I am talking about:
http://www.meijer.com/WireLogic_CleanScreen_690020200.pro
Good Luck and Happy Holidays..
Dec 23, 2008 | Mitsubishi Televison & Video
Replacement lenticular screen for vs6041 60 inch mitsh
we recently cracked our lenticular screen on our 73 in mitsubishi i called the manufacturer and they said they no longer make them. so i looked thru websites to see if i could find some one with a 73 in tv or bigger that they were no longer using or didnt work and i found a guy on www.ksl.com that had an 80 inch tv and we went to go pick up screen cut it to my tv size and it worked!!.
Jun 24, 2008 | Televison & Video
Convergence?
not very likly. The chips on this board have to be replaced and the time involved to replace these and service call can be expencsive. If a new board was available you could be looking at a $500.00 bill plus
Dec 14, 2006 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WD-57733 57" HDTV Logo
268 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
