SOURCE: Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
SOURCE: Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
SOURCE: stops cooking
I had the same problem, but seem to have fixed it last week. Thank goodness, because with 2 little kids, I really need the microwave.
My January '05 model JVM1653 would intermittently have a flickering display then reset itself after about 3 seconds into a full power heating cycle (it was still ok on reduced power). I don't know what the problem was for sure, but protecting the front panel circuit board from radiation seemed to do the trick.
I put a sheet of aluminum foil in a ziplok bag (I used the gallon size, but the 1 qt size would probably do just fine), taped a "twistum" tie with the plastic stripped off the ends of the wire to one corner of the aluminum sheet, and then sealed up the bag and put a piece of tape on the corner of the bag where the wire was hanging out. With the front panel tilted out, I attached the other bare end of the tie to the green ground wire screw. I then "stuffed the ziploc into the open behind the panel while trying to keep the circuit board as shielded as possible. I carefully closed up the front panel, making sure i didn't get the ziplok punctured by the circuit board stuff.
So far so good!!!
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
SOURCE: GE Spacemaker Microwave Clock inop
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
