I have a Sears Electronic Graduate typewriter Model 161 53509850. I don't have the user's manual. The margin is set way to the right and I don't know how to release the margins. Have tried everything!!
Posted by grannydani3 on
Eddie Balen
There are 3 margin keys on the keyboard of this typewriter. One is marked Mar Left, one is Mar Right, and the third is Mar Rel(ease) these are found on the left side of the keyboard, Have you tried either of these? Hope this helps
Posted on Jun 30, 2014
5 Related Answers
Anonymous
SOURCE: Panasonic KX-E508 typewriter losing it's
I have one of these exact ones you cay buy for $50 for the hole typewriter works great!
I can list it on ebay or we can deal threugh paypal.
Posted on Jul 11, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: margin release on a typewriter
Turn off hold down code key...turn on.
Posted on Sep 01, 2008
SOURCE: My Canon S-S68S typewriter has
try to set up the margin at about 3. If the tabs clear nor margin release did not work, check the alignment of the tabs clear from its button to its connector and contact Canon for check-up as well as the Margin Release button..
Posted on Jan 19, 2011
Korede Atunrase
  • 1456 Answers
SOURCE: The typewriter won't hold its
Hello
If the carrier jam hard at the print point, they're bent and are getting stuck in the print alignment fork. You'll have to VERY VERY CAREFULLY make slight adjustments -- and that means corrective bends -- in a type bar that always jams at the print point. You should check for burrs in the type bar itself that can cause this problem too, but most often they're bent if they jam tight. If they move back down sluggishly, either the segment in which they're mounted is dirty or else a spring is disconnected or missing. Make sure the type bars are clean all the way to the bottom; you can just scrape off gunk or use a volatile cleaner that will evaporate (NOT penetrating oil or WD40.) Also make sure there aren't eraser crumbs or grit in the segment.
If this is not the case, then a type-bar spring is a likely culprit. Each type bar normally has a spring associated with it, connected somewhere in the linkage to help return it quickly to the rest point. Look for a battery of springs all in a row inside the machine, and watch as you operate keys to see how they flex and provide 'return power' for the type bars. Look to see if the offending "slow returner" isn't missing a spring, or if it isn't disconnected.
If there's no tension whatsoever on the carriage it's certain that the drawband is either off or broken... or else that the mainspring has become unwound or is broken. Putting the drawband back on is usually easy so long as the original hook or eyelet mounted on the end of the drawband is still in place. Wind tension back onto the mainspring, and then you can pull the drawband under the carriage using a long hook, a wire, a bent coat hanger, a very long crochet hook, fishing line fed through, or just about anything you can think of to get the drawband from the left side of the machine under the carriage to the right side where it attaches. If it is broken, it should be replaced. Sometimes it's possible to use craft edging or heavy ribbon for this, or else fishing line. Look at craft stores long enough and you'll find a number of substitutes for drawband -- remember though that they CANNOT be elastic!
Crimp-type wire connector lugs can be used to replace missing drawband hooks in some cases as well. You'll be able to tell if the main spring is broken if the drawband is off and no matter how much you wind the spring drum backwards you can't get tension on it; note that on most machines a ratchet-style device is used to hold tension on the drum once wound. Make sure this is engaged properly so that tension remains. We will have a separate MAIN SPRING and DRAWBAND section on the site later on in the heavier repairs.
With the rate that machines are being shipped poorly packaged today, we often find that bent levers are a problem... in this case of carriage movement a bent carriage release lever might not move far enough to actually release the carriage. Sometimes, on machines with two levers only one is bent, limiting the other from moving far enough too if they're linked and move together. Examine the mechanism that is connected to the carriage release lever to see if the margin rack moves away from the escapement wheel; if it doesn't, there is likely an artificial limitation caused by misalignment or bending.
One frequent problem we've found on machines discovered in the field, believe it or not, is a stuck back-space mechanism. If the back space is stuck, the carriage won't move at all in most cases. Operate the back space and make sure the key returns all the way up when you release it. Pull the key back up if you have to. Free up the backspace and very often you'll "cure" a "totally stuck carriage."
Posted on Feb 04, 2011
Ray M.
  • 215 Answers
SOURCE: Occasionally, I still have to
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Posted on Jun 07, 2011
Users manual for Panasonic KX-RD 20TH typewriter
Search Results
    [PDF]PDF file created from a TIFF document. - Support - Panasonic
    service.us.panasonic.com/OPERMANPDF/KXE3000.PDF
    PanasonicKX-E3000. Operator's ... accessories recommended in these operating instructions or supplied by the ... typing with one ofthe most advanced electronic typewriters available... 0 Storing Margin Formats ln Memory ..... Set the first TAB at 20.
    Panasonic KX-R530 - Electronic Typewriter Operating ...
    www.manualslib.com > ... > KX-R530 - Electronic Typewriter
    View and Download Panasonic KX-R530 - Electronic Typewriter operating instructions manual online. Operating Instructions. KX-R530 - ElectronicTypewriter ...
Jan 12, 2016 | Panasonic Lands Phones
I have a vintage Sears The Graduate typewriter, but can't figure out the tabs. I can set my margins, but I don't know how to set the tabs. Thank you
Normally same button sets or releases tab mechanical. Next button releases tab to next setting play around or look for the service op,man on internet
Oct 23, 2014 | Office Equipment & Supplies
How do I reset the right side Margin on a swintec 4040 electronic typewriter?
Go to the margin, press but don't hold the mar rel key, space or backspace to the desired position, press R. margin key.
DickyO
Oct 27, 2011 | Swintec 7040 Typewriter
Cannot release my margins on my 6200 portable [email protected] electronic typewriter. do not have a user manual.
Generally speaking go to the margin you want to reset touch don't hold the mar rel key space or backspace to desired location, press L. or R. margin key.
DickyO
Sep 07, 2011 | Office Equipment & Supplies
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
I have an SX-4000 Electronic Typewriter and use it from time to time BUT I do not know how to reset the margins....basically expand them beyond the norm. Please help - I did do the ALT and then the 4 or 5...
Try this procedure to set and adjust the margin:---- Use the "Space" and "Backspace" keys to set the margins by positioning the carrier where you want each margin. Press the "Alt" key along with the "L Mar" or "R Mar" key, depending on which margin you are setting, left or right.Press ALT with L Mar key to adjust margin on left side.Press ALT with R Mar key to adjust margin on right side. ----------------- For more help.Click this link below and check page number 11:---- http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF ------------
This should help.Thanks.Helpmech.
Jan 05, 2011 | Brother SX-4000 Typewriter
How do I set Decimal Tabs?
From the User's Manual:
Margins and For each setting, move point. key(s) indicated:
• LMar to set left margino
• RMar to set the right margino
• MarRei to the!" left of the margino
• TSet to set a tab. Vou set at the left and right margins. Vou • TClr to clear a tab.
• TClr + CRln elear ali The earrier does not margino when the carrier is tive margino Vou type or space through ríght margino saved when the oft.
Tabs
the carrier to the desired point, and press the
the margin.
margin.
MarRel release the left margin, ther Backspace or +- to move
margi n.
You can up to 26 tabs. Permanent tabs exist
You cannot clear these tabs.
CRtn to clear all tabs.
carrier lock at the right margin. The typewriter beeps
about five spaces before the right margin. You can
the right margin. Margin and tab settings are
typewriter is turned.
You can download the User's Manual from LEXMARK:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Look for the title 'IBM Typewriters' at the end of the page, open the list box and select your typewritter model.
Aug 07, 2009 | Lexmark Wheelwriter 1000 Typewriter
Need help releasing margins on an electronic typewriter.
Did you hit the MAR and REL buttons at the same time?
Jan 31, 2009 | Office Equipment & Supplies
Margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
May 26, 2007 | Nakajima AE-830 Typewriter
872 people viewed this question
Marvin
Marvin
