Question about Canon P23-DH Calculator
My SPL - P500 Calculator shows an error when in Prnt mode. Can't use any buttons on screen. Works when in ON mode but not if I press the button to load paper. Error Appears. Tried restting. didn't work
5 Related Answers
Anonymous
SOURCE: Staples SPL-P100 calculator feed
I used a yellow post it note to catch the feeder on the machine, it fit perfectly and caught right away, then I just put it on the paper I was trying to feed in. Worked very well for me.
Posted on Mar 05, 2008
Anonymous
SOURCE: Trouble Feeding Tape into Calculator
have no idea what that meant....
Posted on Mar 12, 2008
Anonymous
SOURCE: Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Posted on Jan 23, 2009
julzgaye
Julie G Workman
  • 3 Answers
SOURCE: loading paper
The entry point is on the back bottom of the machine. Cut your paper into a shallow triangle w/a slight point in the middle. Guide it through the slot on the back, and then lift that point up so that it goes into an almost invisible opening with small silver metal tabs on either side. The paper will want to feed underneath the entire black plastic mechanism, but don't let it. As the instructions indicate, the paper does not actually feed "under the black plastic plate", but through it. After you manage to insert the point of your paper through the correct slot, make sure the entire edge of the paper actually enters so it is grabbed when you push "Feed."
Posted on Feb 07, 2009
Anonymous
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Posted on May 14, 2009
How do I get 2 decimal points in a Staples calculator SPL P100
There is a tab button that controls the number of decimal places you would like. press tab and it will change to 0-2-3-4-A-F showing on the bottom of the screen.
Hope this helps!
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Feb 09, 2018 | Staples Office Equipment & Supplies
Why doesn't the equal button work when I do additions and subtractions?
Your calculator is fine. It is an adding machine first, so it uses adding machine logic and you hit the star button to print the total on the tape. The equals sign is only used when multiplying and dividing.
Adding machine logic is as follows:
5+ total 5
3- total 2
7+ total 9
* print out total
Good luck,
Paul
Sep 13, 2016 | Staples SPL-P500 Printing Calculator
How do I load the paper in my SPL-P500 calculator?
Try making a point and feed it in the right place, the feed roller which is only about 1/2 inch wide should pick up the paper.
Feb 13, 2015 | Staples SPL-P500 Printing Calculator
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Oct 22, 2012 | Staples SPLP500 Scientific Calculator
Where can I get instruction on a spl-p500 calculator
Go to a web search page and type in spl-p500 calculator instruction manual.
May 02, 2011 | Office Equipment & Supplies
SPL-P100 calculator problem
There is a tab button that controls the amount of decimal places you would like. press tab and it will change to 0-2-3-4-A-F showing on the bottom of the screen.
It works. :-)
Joe Stogrin
www.littlejoesauctions.com
Jun 12, 2008 | Canon P23-DH Calculator
Set Tax Rate
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
May 30, 2008 | Office Equipment & Supplies
Canon P23-DH Calculator Logo
old marine
old marine
efs_perpends
efs_perpends
