Question about Allen & Heath Allen and Heath WZ3144 14 into 4 Live Mixer with EQ and Inserts
Where on a 16:2 allen heath wizard would you hook up a 482i sonic maximizer?
Posted by mglover11753 on
Andrew Conroy
    Sergeant:
  • 298 Answers
The answer all depends on what you want to achieve.
  • If you just want to enhance the sound of 1 or 2 instruments / voices you could take a signal out from an individual channel on your mixer using the direct out and insert jack sockets on that channel however this may make it difficult to control in conjunction with teh E.Q. controls on that channel as the Sonic Enhancer would be pre-fade and pre E.Q.
  • Alternatively you could send several mixer channels of your choice through the Sonic by using one of the sub-mix outputs to give a feed to the Sonic, returning it to the main mix either via a couple of spare channels, or the paired stereo inputs that are only routed to the main outputs.
  • Thirdly you could use one of the auxiliary sends to allocate different levels of signal from any number of channels to the Sonic. These are normally used to supply a separate mix to on-stage fold-back systems, monitors etc. Here I would use one of the 2 post fade ones rather than the pre-fade - to avoid negating what you have set on the main mixer e-q (tone controls)/. One advantage of this option is that it allows you to only enhance part of the signal from a particular channel and to allow part to bypass the Sonic without enhancement. I think that this would be my preferred option unless all the auxiliary feeds are needed for other purposes.
  • Lastly you could just put the Sonic on the main outputs of the mixer. This would mean that the same level of enhancement would be applied to the whole mix. As the Sonic Enhancer only has unbalanced (mono) jack sockets this later option does reduce the likelihood of you introducing unwanted radio interference to the system, compared to putting it at an earlier stage in the mix because, as the Sonic is unbalanced, everything else after it in the mix chain will also be unbalanced.
Posted on Feb 02, 2011
I'm using 2 different power amps and the monitor (M) will not work unless I have the L=R sliders up or I can put the M send in the R and it will work the monitors separately. Why and what am I doing w
1st....the output section, "M" stands for mono. The A&E does not have "monitor" sends per say but instead calls them "Aux's." Adjust the proper Aux for the input channel 1-16 and use the Aux output section (row of knobs above output sliders) as the master volume. By using Aux 1-4 (and with more amps) you could send 4 discrete monitor mixes to four different band members. Bass likes his monitor strong but doesn't want to hear other members while guitarists want to hear only himself and the singing drummer...etc.
May 30, 2014 | Allen & Heath Mix Wizard Wz3 16:2...
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
Does Allen-Heath Mix Wizard 16:2 (first generation) require Tip-Ring-Sleeve for Aux sends?
You should use TRS since that is balanced just like XLRs.
Especially for long wire runs. This is if you go for XLR on the other end =
Pin 1= Sleeve
Pin 2= Tip (HOT)
Pin 3= Ring
Normally, in US equipment, 2 & 3 are inverted (3 is HOT), but you got British here, they switch the HOT pin on the XLR to pin 2.
That means that if you run this unit with US speakers your signal will be out of phase. Be careful there... I have lived this with AH boards before.
You can also use normal unbalanced cable for short runs, but I suggest keeping to standards.
Dec 10, 2017 | Music
I would like to buy a case for The Allen & Heath ZED-436 is an audio mixer that gives you 32 mono inputs plus 2 dual stereo channels. Which one do you recommend that can fit it well.Please send me...
Cases are being sold on Ebay, new, from several sources, and if you can't find one specifically listed for your unit, contact the sellers as they custom build them. That is a big unit... expect to pay around $150 to $200 for an ATA type case for it.
Here is an example for a Heath/Allen 420. http://cgi.ebay.com/ATA-CASE-ALLEN-HEATH-ZED-420-ZED-420-ZED420-MIXER-/400127078772?pt=LH_DefaultDomain_0&hash=item5d296eb174
I have bought from them before myself and there are others on Ebay so shop around... You can contact the companies and ask for a specific one and DO compare the size to your unit that they specify as all the companies do not accept returns...
Aug 14, 2011 | Allen & Heath AH ZED 436 32...
I have an Allen & Heath 16:2 DX with two fuzzy preamps. Tried contact cleaner with no improvement. Sounds like a preamp problem - lower volume than the rest of the channels with distortion as more...
NEVER, NEVER put contact cleaner into the faders!!! It removes the lube and the faders will be damaged in short order. Try using CRC226 available at Home Depot in the electrical dept. Use ONLY the CRC226 as there are other CRC products that are not applicable. Squirt some in the center of the slots... not too much and work the sliders... if they improve try a little more... If they are still bad, replace the sliders... it is a MISERABLE job involing removing mass number of knobs, screws, etc... and then getting/finding the replacement fader control. Usually I get them from Digikey.com or Mouser.com and sometimes the actuator tab has to be trimmed to length with tin snips so knob will be at right height. The fader must have the same resistance and TAPER as the original as well as mounting tabs.
Jul 05, 2011 | Allen & Heath Mix Wizard Wz3 16:2...
Allen & Heath Allen and Heath WZ3144 14 into 4 Live Mixer with EQ and Inserts Logo
334 people viewed this question
Top Allen & Heath Music Experts
Marvin
Marvin
Are you an Allen & Heath Music Expert? Answer questions, earn points and help others
