Get a clean white rag and soak it up is it coolant color or is it clear water? coolant color or smell you have a bad heater core or hose connection to heater core is leaking. clear then you have a window seal or vent and possibly a pluged drain tube for the air cond. I don't know what state your in or water color so this is the best diag i can give but its a start for your checks
Does this happen when using the a/c? The evaporator drain tube may be clogged.
SOURCE: water in the rear passenger footwell
Not unless it was blowing like stink. Was a rear window left open? Water could get in around the rear window and find it's way there. Have someone spray the car with a hose while you're in it or ride back there through a car wash. Have a friend help and you buy the treat.
SOURCE: 1998 Ford Mustang GT convertible...recenly water
Take the car through a car wash and watch for leaks. Usually window seals. You can buy replacement window seals
SOURCE: water collecting in the rear passenger footwell
do you have a sunroof?? open the front doors and look for a rubber spout sticking down at a 45* angle. milk it a bit and water might flow out. I carefully cut mine a bit so this wouldn"t happen again.,..
If this did the trick please let me know
SOURCE: water in footwell on renault clio 2004
my brother-in-law had this same problem with his truck and we fixed it with clear sylicone all the way around the windshild and almost all of the firewall. sence we did that he has not had any more water problems.
SOURCE: 2007 XKR Convertible: condensation dripping on passenger side footwell...
that would be your heater core going out.
Thanks for your help. The water is clear and only gets into the footwell when rains.
