Question about Cameras
I have a minolta MD lens 35-70mm f3.5 that is stuck at 70mm. how do i get it unstuck?
Posted by joyboys2001 on
Anonymous
    New Friend:
Hi!
Is your lens having a "macro 1:4 - 1:7" green sign near the "70"? If it does it may be stuck in the macro position... ? To put it back into the normal "35-70" zooming position just press the little black and greenish button on the lens, turning the zoom anti-clockwise.
Well... i'm Italian and tonight my english is particularly stuck.. But I hope this could help you!
Let me know, cheers :)
Emi
Posted on Feb 02, 2011
Get barrel unstuck
there is lens lock slider, slide to unlock the zoom.
75-250mm F3.8-4.5 tamron lens compatible to a
As long as you can get the correct Tamron Adaptall 2 mounting for it, then it will fit. They're no longer made and not always easy to obtain at reasonable prices.
Adaptall 2 mounts for Minolta autofocus were never made, but the earlier MD mounts were, and they will fit any Minolta or Sony SLR. Obviously, there will be no autofocus but you will also find that you have to focus with the aperture ring wide open and then manually meter and take the shot after you have selected the aperture which you require.
1helpful
Can I use MD lenses on my Minolta 5D or do I need an adaptor
The two lens mount systems are incompatible.
You can find adapters on ebay (listed as MD to MA or MD to Dynax) but they come in two varieties:-
The first is a straight converter, it allows the MD lens to attach to your camera, but as the lens is further away from the sensor/film plane than it was designed for you lose infinity focussing so the lens is only good for close-ups.
The second type is more expensive as it incorporates corrective optics to compensate and allow infinity focussing. But by introducing additional (and often suspect quality) optical elements you inevitably have a trade-off in image quality and may experience greater lens flare and chromatic aberrations.
Either way, an adapter leaves the MD lens completely unable to communicate any information to the camera body, and the body is unable to automatically stop the lens aperture down when taking photos. In practice, this means that you must use the camera in fully manual mode, manually focus at wide open aperture and then turn the aperture ring down to whatever you wish to use to correctly meter the light level in order to set the correct shutter speed.
All in all, it's a complete waste of time in my opinion and it would be simpler and far cheaper to obtain a suitable Minolta MD mount body to use with those lenses alone. They go for free/peanuts now, like many 35mm SLR bodies and you can try your local FreeCycle/Freegle groups before shelling out anything. Rare/collectable models aside, no MD mount body should go for more than £10-£20 unless it's guaranteed to have been freshly serviced with new batteries.
As you may be aware, newer Sony lenses will fit your 5D as they use the same mount, but they aren't anywhere near as cheap nor plentiful as MD lenses.
Hope this helps, all that I ask in return is for you to take a moment to rate my answer.
Have multiple Minolta X-700 bodies, the 400mm Minolta MD lens, does lock onto one body but not some of the other camera bodies. Any idea why?
If your other lenses lock on to all of the bodies, then it is quite likely that the notch on the mount edge of the 400mm is worn. The notch is located about 90 degrees clockwise from the red marker dot on the lens barrel. I doubt if there are new replacement mounts for that lens. You may be able to square up the edges of the notch with a small file.
I have a Minolta 700si and want to put a MD Zoom Minolta Celtic 100-200mm lens on it. Is there an adapter that I can get to use this lens and have it fit properly?
There were years ago, but you did not have auto-focus or metering as I remember. Also there adapter had an optic that was not too good so the lens lost a lot of quality when used. Get an SRT-101 for use with the Celtic lens.
1helpful
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
2answers
Where to purchase Minolta MD/MC lens to Sony A700 adapter in Australia
the best way to get lens to go the nearest outlet of the brand choice, this is to ensure you're getting the right and secure product and avoid getting you're camera malfunction.
Sep 15, 2009 • Cameras
1helpful
3answers
QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
