Hello
What you can do is to try to find out if there really is something stuck. Usually, you can find the problem in the space between the grinder basket and the filter basket. If some coffee grounds are there, clean it.
Mix clean water with vinegar and dip a clean towel in it. Use it to clean that area. It will help dissolve the sediments and the coffee essential oils that have clung to the slot. If this is already clean, move on to the grinder motor.
Usually, Cuisinart provides a cleaning brush. Use this to clean the motor and remove any visible ground coffee that may have stuck there. Once you have cleaned this area already, it should work nicely again. Try grinding and it should work seamlessly.
Now that you have solved your Grind & Brew coffeepot problem, you should be able to enjoy a good coffee experience.
THANK YOU FOR VISITING FIXYA
