SOURCE: air con not working. Operation
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
SOURCE: I have an ASTA24LCC split system and the unit is
Voltage issue? There should be a diagnostic chart on the wiring diagram.
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.
SOURCE: Hi there, we have a
Indoor coil thermistor is short. Replace it. It's located in indoor coil ending with copper sealed tub. Thanks.
