Just check at upside where paper iscoming out after print, there you can see the two black flips to monitor the paper out position, this flag sensor got dusty this error apprears, remove back cover, you can observe left side this sensor, just clean it..
This is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of
invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during
transmission to the printer. Other causes include poor quality parallel
cables or poor connections, To solve this try this solution step by step
Turn the printer off and then back on.
Try printing a job from a different software application. If the job prints, go back to
the
first application and try printing a different file. If the message
appears only with a certain software application or print job, contact
the software vendor for assistance.
f the message persists with
different software applications and print jobs, disconnect all cables to
the printer that connect it to the network or PC.
Turn the printer off.
Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
Remove all EIO devices from the printer.
Turn the printer on.
If the error no longer exists, install each DIMM and EIO device one at a
time, making sure to turn the printer off and back on as you install
each
device.
Replace a DIMM or EIO device if you determine that it causes the error.
Remember to reconnect all cables that connect the printer to the network or computer.
If the error persists, final option is replace the firmware I hope this solution will helpful 4 u Please don't forget to click on Four thumbs which are given below if it is helpful THANKS & Keep Using fixya
Thank you for contacting FixYa with your printer error.
This error indicates a Printer Device Fan has error has occurred.
HP troubleshooting steps include:
Turn the device off and then on.
If the message persists, contact HP Support.
http://www.ipslaserexpress.com/PDFs/3005.pdf User Guide Page 117
Hope this helps helps. Please keep us updated and remember to rate this answer.
The HPP3005 Error 59.50 indicates a main motor (M1) failure. This could be caused by a seized toner cartridge, try replacing the toner. If the error persists the motor likely is bad and will need to be changed. The Part Number for the motor is RK2-1488-000CN http://partsurfer.hp.com/Search.aspx?SearchText=RK2-1488-000CN Thank You
This is a firmwere error for firmwere go www.hp.com/support/ljp3005 for letest firmwere download & install.
If problem persists then replace the formatter card.
thanks.
first your system windows has currupted get the fresh install the os and then install again the problem has solved because your system has effected for viruses than epson dfx -9000 matrix printer showing error
I had refilled the catrige, then when I start to print a 'service
error' window will appear. At the LCD screed shows E.. 4 ..2. I believe
the printer simply assume the catridge is depleted, but how can it
happened as I already just refilled it. How to make printer detected
the catridge as a full? I really hope you can solve and make my
refilling mission succesful and my printer work again.
