Hi.
Liquid damage operates in two ways. Liquid causes shorts and contacts that can blow components causing permanent damage, or that may just temporarily affect the unit for few days (camera usually won't start until liquid inside has dried).
Oxidation following the contamination may cause permanent damage to boards and components. In some case oxide can be removed disassembling the camera and using circuit cleaner solution.
The incident was caused by soda. This make things slightly worse, as the ingredients may help oxidation.
When there is liquid damage, any electronic part inside the unit may result affected. In some case the damage may be only temporary, depending on how lucky you are.
The repair cost depends on what parts must be replaced. In the best case the technician disassemble the unit, cleaning the boards and allowing dry up.
Before sending the camera for repair, remove the internal battery, and allow the camera to stand in a dry place for 4 or 5 days. Leave battery compartment open.
Leaving battery in after the damage has occurred, or any attempt to start the camera while liquid is still present can make things worse.
If that does not work, you can get a quote on repair contacting Canon at the service number listed on the owners manual, or you can get a quote from a third party service here: Repair.
Repair will approx. be between $40 and $80.
Regards.
Ginko.
hmmm... stop turning it on yet.. let it dry for maybe 24~48 hours then try to turn it on. If problem persists, contact your home support from this LINK.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Splenda has been added to a new type of Diet Coke product in 2005 called
Diet Coke Splenda. Pepsico. uses Splenda as well in its Pepsi One product.
Mountain Dew contains Splenda as well. Other products that use Splenda include
Dr. Hansen's Diet Sodas and all Dr. Rite soft drinks.
Diet sodas are definitely healthier than regular sodas, but they have
their disadvantages as well. The advantages are:
They don't contain any sugar- you won't gain weight
from them and they won't raise your blood levels.
They contain a very low amount of calories- you can
drink few servings of diet sodas without having to worry about the calorie
count.
The disadvantages of diet sodas are:
They are not as sweet as the regular sodas, which
some people will have hard time to get used to.
Artificial sweeteners used in sodas pose several
health risks. For example, aspartame has been linked to causing cancer,
Alzheimer, and birth defects.
• Diet sodas can actually make you gain weight (indirectly) because people who drink it tend to look for sugars from other types of food.
it has had time to dry. it happened several days ago. I hoped that would solve the problem.
I guess the link is my next step.
thanks
I dont want to go to canon because I will end up frustrated because I dont have a warranty.
You were nice but this didnt give me a solution. Perhaps I didnt word my question well. I need to know if it is worth sending away for repairs after getting wet. My macbook was ruined from when a cup of tea spilled on it.
