HOW TO INSTALL ROOT (Authority) CERTIFICATES ON S40 MOBILES
[ Edited ]
Options
15-Jul-2009
04:02 PM
- last edited on
15-Jul-2009
04:05 PM
Recently i bought a 6500 Classic and stupidly deleted my Authority Certificates.
After trwaling the net for info on how to re-install certificates i couldnt find an answer apart from NO YOU CANT DO THIS.
Well to that i say NUTS!!! because you can and i will show you how by simply following these steps.
1. Create a New Folder on your desktop and call it whatever you like.
2. Open notepad on your computer.
3.
Copy the text below into the Notpad file. (I got this from some website
as they were using it for smething else but it does work so thanks to
them or thanks to you if this is yours)
<?xml version="1.0"?>
<!DOCTYPE html PUBLIC "-//WAPFORUM//DTD XHTML Mobile 1.0//EN" "http://www.wapforum.org/DTD/xhtml-mobile10.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Install root CA</title>
</head>
<body>
<p>
<a rel='nofollow' href="der1.cer">Download a CA Cert1</a>
<a rel='nofollow' href="der2.cer">Download a CA Cert2</a>
<a rel='nofollow' href="der3.cer">Download a CA Cert3</a>
<a rel='nofollow' href="der4.cer">Download a CA Cert4</a>
<a rel='nofollow' href="der5.cer">Download a CA Cert5</a>
<a rel='nofollow' href="der6.cer">Download a CA Cert6</a>
<a rel='nofollow' href="der7.cer">Download a CA Cert7</a>
<a rel='nofollow' href="der8.cer">Download a CA Cert8</a>
<a rel='nofollow' href="der9.cer">Download a CA Cert9</a>
<a rel='nofollow' href="der10.cer">Download a CA Cert10</a>
<a rel='nofollow' href="der11.cer">Download a CA Cert11</a>
</p>
</body>
</html>
4.
Save the Notpad file as type ALL FILES but when naming it just call it
cert.html and save it to the folder you created on your desktop earlier.
5. Now downlaod the Root Certificates you need to the same folder on your Desktop.
6. When saving the first Certificate to the folder call it der1 ((make sure not to take out the file extension eg .cer)) then the second der2, third der3 and so on and so on till you get to der11. (Dont worry this will not rename the certificate when it installs on your phone.)
Example of what the files in your Desktop folder should be called der1.cer, der2.cer etc etc.
7. Now transfer the whole folder from your Desktop to your Mobile phone. (I did this by using Nokia PC Suite.)
8.
When the folder with the certificates and hmtl we made have been
transfered to you phone navigate using your phone to that folder.
9. Go into the folder and open the cert.html file. (Your browser will now open a page with 11 download links available)
10.
Now all you have to do is click on each link and accept each
certificate remembering to save and they will install on your phone. (On
my 6500 Classic i can check this by Navigating through my phone to
Menu>Settings>Security>Authority Certificates)
Notes:-
Some errors you may receive when trying to download the certificates
through your phone browser may be Already Exists, Expired Certificate
and the most annoying is Corrupted Certificate.
Already Exists - Shouldt allow you to save (DO NOT SAVE IF IT ALLOWS YOU)
Expired Certificate - (DO NOT SAVE)
Corrupted
Certificate - Install the certificate on your computer first, then go
to Tools>Internet Options>Content>Certificates.
(save
the certificate to other people tab) Browse for the certificate you
installed then export it in DER format to the Desktop Folder you created
then start process over again to get it onto your phone.
Remember to delete any certificates as you go that you have already installed so you dont get mixed up.
Any issues reply and i will do what i can to help and if anyone has Hutchinson 3G Root Certificates please let me know.
From where can i download root certificates??????????
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link Rm 578 file /Rm 579 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal modestart from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
It is impossible to recover without flashing or updating firmware.So try to do this trick.before you try please read carefully.
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link Nokia flash file or 2730 file and install it to C / programme files/pheonix..after finished this installation open pheonix Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
I need certificate for nokia 2730 class
I have nokia2730c-1 cirtifit has be deleted how to download help me
