Question about Connex Radio Communications
I have a connex 3400hp radio. Will the new magnum sx-175-3 power cabinet fit this radio?
Posted by Vernon Smith on
ePowerAmps CB Radios
    New Friend:
Yes
Posted on Apr 25, 2011
I want to peak and tune my connex 3400hp
people think that if they peak and tune a radio it will work better. First, if its brand new from the factory you shouldn't have to,all you should have to do is lower the dead key raise the modulation and you are good to go . The proper way to do this is with a spectrom analyzer . Do you have one? Cheap on ebay ,may 4000-5000 dollars but if you get one and set that radio perfect you should hear anyone complain that you are interfering with their radio.
Sep 05, 2016 | Connex Radio Communications
I have a Connex 3400hp and it just topped receiving all of a sudden while driving down the road
did you check to see if it was still plugged in.maybe the reverse polarity diode or a crack in the pcb
Feb 16, 2014 | Connex Radio Communications
Converting 10 meter to 11 meter on Connex CX-3400HP CB RADIO
Turn the mode switch to the setting you want and leave it there .
Jan 10, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
I have a connex cx-3400HP d and a r not working until the unit get's hot
Take it to a good cb shop radioactiveradios do really good work on connex radios
May 27, 2012 | Connex CX-4300HP CB Radio
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
After you convert the connex 3400hp from ham to amature, what do you do to tune it in where you can reciever and talk? and also how do you tell what channels are regular,uppers,and lowers?
you will need a frequency counter, to show the channels. 1-40 and the others are allocated as frequencies. there are lists available showing ch1 band A is ??? so forth. there shouldn't be uppers or lower on it its just a AM/FM only radio NO SSB.
and these ARE NOT AMATEUR / HAM radios!!!!!!! these are EXPORTS...
Dec 12, 2010 | Connex 3300 240-Channels Base CB Radio
I just purchased a connex 3400hp and my cb freinds tell me that my other radio sounds better than the cx 3400hp,my other radio is a cobra 29 ltd classic.my 29 has more audio and modulation and both radios...
The Cobra 29 has always been a good talking radio and is preferred by truck driver mainly for that reason! The Connex is a great radio in it's own right but sometimes needs a little help. I would suggest a power mic and there are many to choose from but Astatic is a clear winner! My two cents for a suggestion!
Mar 07, 2010 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
122 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
