Dell DJ Ditty MP3 Player Logo
Question about Dell DJ Ditty MP3 Player
When i plug in my dj to charge it cause its dead and wont turn on, but any way when i plug it in it dosent show up on the computer and ive plugged it in before so ITS FRUSTRATING!!!!!!!!!!!!!
Posted by jcjarecki8 on
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Dell DJ Ditty
We may be in luck - I actually found an owner's manual for this one. Did you run the installation CD first? If you don't, Windows will load it's own, possibly wrong, drivers.
Make sure you didn't accidentally press the player's lock button:
The keys on the Dell DJ Ditty have been locked.
Unlock the keys by pressing in on and holding the
Volume/Scroll/Select dial until the lock icon disappears.
Reset method - Insert the end of a thin object, such as a straightened paper clip, into the reset button (near the headphone jack).
Also make sure your operating system is Windows XP - it won't work on anything before or after.
The Musicmatch service that this player was tied to was discontinued in October 2007, so your going to have problems even if we get it working again. Use Windows Media Player 10 instead (downgrade if you have the current version 11 installed).
Let me know how everything turns out.
-Tha Mp3 Doctor
Posted on Jun 13, 2008
Anonymous
SOURCE: how do i reset it.? i charged it on the computer fully now it wont turn on please help
Yes you can reset it but i have the same problem. To reset you need a paper clip. Insert the tip of the clip into the small hole beside the head phone jack and gently push.thats it.Good luck.
Posted on Sep 06, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Files on Dj Ditty won't show up on computer..
Sounds like you need to reformat the player, but here is my Dell Ditty troubleshooter:
Dell DJ Ditty
http://support.dell.com/support/edocs/systems/P97347/om/OM.pdf - manual
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell DJ Ditty – from Dell
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid= - Firmware for Ditty
Did you run the installation CD first? If you don't, Windows will load its own, possibly wrong, drivers.
The Musicmatch service that this player was tied to was discontinued in October 2007, so you’re going to have problems even if we get it working again.
The DJ Ditty does recognize DRM-encryption for WMA files – make sure the license is up to date, or convert the file to mp3 format if you are experiencing licensing issues.
If you are experiencing frequent freezing, or a file system/corruption error, or getting the “Warning! Reformat with Firmware Updater!” message, there are two ways to format the DJ Ditty:
Format using Windows Media Player:
Run Microsoft Windows Media Player.
Connect the DJ Ditty to the computer.
Click the Sync button on the top of the menu.
Click the "Format storage media" button on the right-hand side of the screen.
Disconnect the DJ Ditty and power it back on.
Reload or upgrade the Firmware:
Download and install the latest firmware from http://support.dell.com
Run the firmware upgrade program with the "Format Data Area" checked.
-Tha Mp3 Doctor
Posted on Dec 14, 2008
Anonymous
  • 6 Answers
SOURCE: pocket dell dj will not charge
It sounds werry mouch like a bad battery. Have you tryed to seek online for a report on the LED blinking code?
Posted on Aug 17, 2009
Anonymous
  • 105 Answers
SOURCE: wont charge battery
Have you tried using another charger?
Posted on May 29, 2010
My battery went dead. plugged it in and wont do anything
mine is doing the same. i have a SanDisk 4GB mp3 video player & mines went dead too and it will show it charging for a few seconds then it will just stop & it will just show the connected sign. try holding the power button for 15 to 20 seconds. maybe that'll work
Wont charge
I would try to open the battery door on the device and remove the battery for about 1 minute and then replace the battery and door and try to charge the unit and turn it on
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Laptop wont turn on
Try removing the battery and plug in the power adapter and then power on your laptop. If this doesn't work, put the battery back in and plug in the power adapter and try turning it on. If that doesn't work then take the power cable out and try with only the battery. Try in this order and see if it comes back up, if not, you may have some dead hardware.
Nextar MA715 MP3 player wont take a charge.
Best first bet is dead battery. If it is a special battery then do the costings for the repair as it may be cheaper to replace the player.
My zune wont charge at all even when its plugged in
OK this seems weird but if you have like a Nintendo Wii or a PlayStation 2 or 3 take you sync cable and plug your zune into the usb port on the system because sometimes the battery is just so dead that it dosent have enough power for the computer pick it up. mine done this a few days ago and i left it plugged into my Nintendo Wii over night and it started working again
My Lyra Dosent Turn On
sir u need to recover ur dead digital player and how its work follow me!!
1/ try to download a flash tool from the main site of ur product
2/visit this and keep uuuuuuuuup
1helpful
Charging, downloading
your lap top probbubly has a power saving seting for your usb ports ..try changing that or pluging into a regular desktop computer... it will turn on when it is charging and show a lightning bolt going through the pickture of the battery...
if that dosent work make use of the warenty (if it is still useable)
Dell dj gen 20
it is possible the the battery cable is unpluged
My computer wont detect my e200
Dont turn it on and plug it in. That had happened to me and that fixed it.
Top Dell Audio Players & Recorders Experts
David Shaub
NOEL
NOEL
Ngoro
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
