Question about Jwin MP3 Player
Bought micro sd card reader mp3 player from light in the box and the disc and instructions are in chinese? should have known it was shipped straight from china. so needless to say i need help putting music on it is it a FAT format or a FAT32 or is there just a problem with this mp3 player? really could use some instructions? can you help?
Posted by christine89814 on
Anonymous
  • 215 Answers
If you connect it then it's internal memory and any microSD card installed should show up as drives in My Computer. You can drag and drop music files into them.
Here is a Jwin support page www.jwin.com/support.asp?type=6
If you have the model number you should be able to download instructions.
At the very worst you could download a couple and see if the picture matches yours, or the instructions work on yours.
I had one turn up, no instructions or CD at all and displaying Chinese.
The model number was on the back, and it was a standard unit, presumably tested before shipping by a Chinese user and not reset to default.
An English manual will tell you which counting from the top those incomprehensible characters mean, and it will most certainly have an English setting.
Mine had some languages on the Chinese setting and displayed in roman letters and the second one down in Hungarian was Anglo. Google Translate could help here also.
Think of it as a MP3 player, card reader and logic puzzle.
I wish you success.
Posted on Feb 02, 2011
I've just bought a LAZER (MD111AXBX) MP3 PLAYER Can't work out how to download my music on to it. Can you please help me?!? Many thanks!
This reader is sold without any memory... you've to introduce a Micro SD Card into the LAZER MD111AXBX and to download into the MicroSD Card your MP3 musics through the USB connexion.
1helpful
2answers
How shall i put in a kingston 1gb micro sd in a All in 1 card reader
You should have 2 components with your micro SD card. The card, a small adaptor and a large adaptor. All you need to do is see what size adaptor your read needs. You place the card in the tiny slot in the adaptor and slide it in the reader. The computer will find the micro SD and install the driver to read it. Then it will give you an option to open the files. That is how 99% of them work.
1helpful
How to Add 16G Micro sd card to Sansa c240 MP3 player?
is that mp3 player have the facility to add memmory card... then see in the side of the player their will an space given to insert that mcardf
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
4helpful
3answers
How do I use the mico sd card on this player?
I would recommend here:
http://www.newegg.com/product/ProductList.aspx?N=2070070068+1053118914&Submit=ENE&SubCategory=68&Tpk=micro%20sd
It honestly doesn't matter what brand of micro SD you stick in your MP3 player, so I wouldn't worry too much. Micro SD's are much smaller, so no, you can't use a normal SD in a Micro slot. Most however do have an SD "shell" that you can stick your Micro into, and use just like a normal SD card. Also I know that MOST mp3 players allow you to add pictures, videos, etc, and having a Micro SD inside should allow you to add things directly onto it, so i dont see why you wouldnt be able to access the contents of the Micro from your MP3.
Hope this helps! :)
2answers
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
How to sink micro sd card with player
You should probably just copy the mp3 files directly from their source folder over to the micro sd. To do this, put the micro sd into some type of adapter that will allow the computer to read/write to it. There are usb sticks that do this and there are SD adapters you put the micro into so you can use a media reader/writer with it. Once you have the card seen by the computer, just drag and drop your MP3's into the drive letter corresponding to the memory card. After that is done, put it back into the player and turn it on. I should find all your songs and make them available to you.
Sandisk 4gb microSdhc wont read in computer
few computers nowadays read SDHC out of the box. you will need to purchase a SDHC reader that plugs into your USB port.
1helpful
Micro sd 4gb card problems.
Check the Sansa tutorials at http://www.sandisk.com/Retail/Default.aspx?CatID=1468
to make sure you have followed all the steps first.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
2answers
Sansa e250 won't recognize sd card.
Try charging your mpr player first. -is your SD Card brand new and with warranty? I think its deffective. Return it for replacement.
Jwin MP3 Player Logo
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
k24674
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
