Sony Playstation 3 (PS3) Console Logo
Anonymous Posted on Feb 01, 2011
I was switching my ps3 from hdmi output to the red,yellow and white cords and after i accepted i switched my tv to av1 and there was picture and sound but it then asked me what format and i selected 1080p and the screen went blank, now i can't get video output on hdmi or av1 on my tv but i can hear the cursor move when the setting is in hdmi on my tv how can i fix this?
Anonymous
Level 3:
President:
  • Master 2,653 Answers
  • Posted on Feb 01, 2011
Anonymous
Master
Level 3:
President:
Answers
2653
Questions
Helped
744839
Points
7663
Easy to fix so don't worry ;)
While the PS3 is off (solid red led)
Hold down the power button until you hear the SECOND BEEP, quickly release.
This will reset the video settings back to default.
  • Anonymous Feb 02, 2011
    thank you soo much i was hoping i wouldn't have to try and reset it with a blank screen saved me alot of time i will get back to you whether it works or not
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
2answers
My new PS3 wont seem to connect to either audio or video connections? is there a general problem with this tv model? i tried both the R/L audio's and for the yellow cable i tried that in all of the...
Sometime the game cable connections itself have bad conductivity and shorted,tries twist and shake the cable u hear humming audio and see flashes of picture in and out?Tries hook it up with a single HDMI cable cord,have a more success with many LCD tvs models.U have a HDMI cable or try Ebay.com,Amazon.com to buy one.
Im not getting anything (soud or picture) with the red, yellow, and, white cords. thats because it is set for the HDMI cable. how do i get the picture to come in without a HDMI compatable TV?
Sounds to me like you will need to plug the PS3 into a HDMI capable display and change the output settings on the PS3 to composite / AV.
Then reconnect to the non HDMI TV. The red, yellow and white cables should now work.
PS3 used to work on TV in bedroom and on TV in lounge, now it won't work on TV in bedroom
I believe your Lounge TV is an HDTV and your Bedroom TV isn't, This is what you have to do:
1. Connect it to
your Lounge TV with an HDMI cable and a red/white/yellow cable.
2. Turn it on and go to the display settings and switch it to the composite cable setting.
3. Change your TV channel where you would see the red/white/yellow cable and accept it that way.
4. You should be all set. Take it to the regular TV and connect it with the red/white/yellow cable.
cheers :)
Fixed ps3 ylod but now no picture and sound. what could this be? and how could i fix it?
If your tv output it av (red white and yellow cables and av connection), then make sure you push the cables in properly. If that doesn't work then if you have a ps2, use that av cable and switch it with your ps3 one (theyre both the same). And if your output is hdmi, than either the cable is faulty, the tv or the ps3. And for av connection if none of those options worked then its probably your ps3.
I CANT GET MY INPUT TO GO THRU THE HDMI CORD
There is a little switch at the box where it splits from normal RCA to the HDMI on your output cable....flip it to the other position.
I have two tv's and on one i use the red, white, and yellow cord for my video and the other i use the hdmi cord. Once i used the hdmi cord on one tv when i went back to the first tv with the other red,...
Tuen your ps3 off, then turn it back on but keep holding your power buttin down until you hear the beeps. It will restore you original display setings.
14helpful
2answers
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Model 60PL9200D/37 no sound
What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
For a red, white, and yellow cable:
I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
If the connection is good,
Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
  1. Press the 'MENU' button on the remote control.
  2. Press the cursor up/down to select SETUP and press the cursor right.
  3. Press the cursor up/down to select SOURCE and press the cursor right.
  4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
  5. Press the cursor up/down to select AV1 and press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
For HDMI,
The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
Answer
  • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
  • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
  • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
  • For detailed information, please refer to the user manual of the accessory device.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
