SOURCE: how do you clean an
Generally, there is a latch which closes the door on some units...on others it is electrically actuated. Turn the controls to clean. Generally, there is a function control and a temperature control which must be activated. This will latch the door electrically. A two hour cycle is about right for most soil, if you're given a choice. Ventilate the area...it smells! The door will unlatch about half an hour or more after the cleaning stops.
SOURCE: Modern Maid Wall Oven DGO757 ignitor gets
I have a Modern Maid Wall Oven and the pilot light waant stay lit. What's the best solution?
SOURCE: I do not know how
The self cleaning feature is quite complicated for which you need to follow the owner's manual. If you have problems with this system, call a skilled repair person. However follow the bellow instruction if it helps:- Thank you for contacting Fixya.com Please get back to us if you have any further query. Have a nice day.
First turn off the oven and allow it to cool.Then remove the oven racks, broiler pan and any other items from inside or on top of the oven, and from the storage drawer.Wipe the inside of the oven door edge using a cloth dampened with water. Wipe the inside 1 1/2-inch area around the edge of the oven cavity frame. Don't clean the gasket.Now close the oven door, and press the "Self Clean" button in the control panel.You need to press the "More" or "Less" arrow buttons to choose a cleaning time and level. The options range from 2 hours and 30 minutes to 4 hours and 30 minutes, available in 15-minute increments. You can choose light, medium, or heavy, depending on the amount of soil. The cleaning cycle starts seconds after choosing a level. Choose the time based on the amount of soil. Now press the "Start" button to begin the cleaning cycle. The oven door automatically locks and stays locked until the cycle completes and the oven cools down.
When the auto clean function is finished and the "Lock" message turns off, unlock and open the oven door and wipe out any ashes using a cloth dampened with water. Replace the oven racks and any other items.
Hope this helps
SOURCE: How do I remove the
Hi Please click on this link to follow the step by step
instructions that will help you in removing the door. Hope this helps...please post back for further assistance. Daniel
