SOURCE: Microwave oven won't work
The most common causes of a microwave's being "dead" is a blown fuse and a blown thermal cutout (or thermostat) in the area of the magnetron. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
SOURCE: Microwave ahs power but doesn't heat.
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
SOURCE: Microwave pops and sparks when running. Nothing
in the top of unit is a round cover and damage is coming from here. This is serious and needs to be checked out. the cover contains a stirrer that moves waves around<<circulates them>> in this cavity probably paint is thin and allowing waves to penetrate metal of cabinet. Call manufacturer and see if there is anything they will do for you before taking it upon yourself to either get repairman or get rid of unit.stirrer is probably damaged and cabinet burned from waves.
Oh, it was the waveguide cover. Just needed replacing, didn't cost a lot, took a wee while to come from the distributor though.
