If the water is freezing in the supply tube then its not water valve or icemaker fault.Its the fault of defrost board.Its not letting the unit to defrost on time and this is causing the problem.If water is faulty then water will over flow or no water will flow,if ice maker is faulty then it will not make ice.Try manual defrost reset
procedure: ----
First unplug the unit from
main power outlet. Then empty whole unit completely. Then keep both the doors open.
Wait for 24 hours. All the ice collected on the coils and in the
freezer section will get melted. Clean the water from the sections.
Then Connect the power cord of the unit to main power outlet after 24
hours/.Then set the temperature to normal in both fridge and freezer section.
It will take near to 4 hours to get run in its proper cooling cycle. Then check,
if the problem returns again. If the same problem occurs then it's defrost problem.
The defrost board and the defrost thermostat/heater is not functioning properly
and it has to be checked and replaced.you
can get the required parts from online sites like:--- www.repairclinic.com or
from searspartsdirect online site.---------This will help.Thanks.Helpmech.
