SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
If you own a Whirlpool Cabrio and are experiencing an F1 error, you're unable to finish or start a load of clothes. When the Whirlpool Cabrio displays an F1 error, this means the the control board is having difficulty communicating with the motor.
To fix your F1 error, you can first try to unplug your washing machine for 15 minutes and then plug it back in. If this doesn't work, you will need to replace the control board. The only tools that you need to replace the control board is a Phillips screw driver and a 1/4" hex head driver. Be sure to unplug the machine from the electrical outlet before performing any repairs.
After unplugging your Whirlpool Cabrio washer, carefully pull the washer away from the wall (Watch your drain hose and the two inlet hoses.) Next unscrew the 3 screws located on the back of the Whirlpool Cabrio. Next, take a picture or make note of where each plug connects to the control board. Next, unplug each plug and the pressure tube. Lastly, unscrew the 1/4 screw then remove control board. Replace with new control board and reverse your steps to install. The new board will fix the Whirlpool Cabrio F1 error.
