Question about Tag Heuer TH 5104 Sunglasses
Replace rubber nose pieces - Tag Heuer TH 5104 Sunglasses
Posted by ssage358 on
jhaessica
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
Use small pin or maybe hairpin to unclog the said rubber.
Posted on Feb 02, 2011
The windshield washer line detached. How do you reattach it without removing the hood?
Needle nose, make sure that the washer nozzle itself has not broken off. if there is a hard piece of plastic inside of the rubber hose you will need to replace the washer nozzle.
Apr 04, 2016 | 2006 Kia Spectra
The rubber nose piecce is broken, can it be replaced and where can I get it at area code 33436
Usually with stuff like that they are too small too fix. Your best bet is to find someone around you that has the tools to put it back on or to replace the actual piece. Or can try asking at glasses stores to see if that could fix it, but if you don't have the piece it could be difficult. If you don't have the piece then you should just replace the glasses because it is hard to find the same exact piece. Also if these glasses are prone to having that particular piece fall of you should invest in different glasses.
Jun 21, 2011 | Adidas A152 Sunglasses
I have lost the rubber nose piece. Can i order a replacement?
Sure you can.You can order them on line or to go to the store that have their brand and order there.
Jun 12, 2011 | Tag Heuer TH 5101 Sunglasses
I have a pair of Tag sunglasses. I believe the model number is 6008 102 but the full numbers that are on one temple are 115/1 30 TH 6008 102 59 1703. There is a rubber nose piece that is mounted on a...
go to the official Tag Heuer website, www.tagheuer.com, look for the retailers in your country chose the one nearest to you and contact him The name of the model is TH 6008 102
May 17, 2011 | Tag Heuer Clothing Accessories
Rubber nose piece has split - barely hanging on
Hi.
The part (or the glasses) must be replaced. Cheap repair done with superglue is not a good solution. Please contact Nike customer support using the link below:
Athletic Sport Sunglasses & Technology ' Nike
Mar 27, 2011 | Nike Counter Sunglasses
Replace rubber on nose pieces
go to an opticians and it will only cost a few pence and they will replace them and fit them so they sit snug for you
hope this helps
Feb 01, 2011 | Tag Heuer Clothing Accessories
I have a pair similar to the EV0253 and the rubber on the nose piece bridge has disintergrated due to interaction with sunscreen. Can I replace the nose bridge piece?
hi
you can certainly replace your nose piece bridge by taking your cool sunglasses to the show room where you brought with the bill they have given you but you should have warrente or you need to pay for it but it wont cost much . or you can vist the site below ,for reparing your sunglass
http://eyewearus.com/pd.asp?prod_id=10918&txt_brand_id=174&cbocat=1
Nov 18, 2010 | Nike EV 0253 Sunglasses
I have been rebuilding Hitachi nalers for about 2 years now and this one has me stumped. It works fine if you single shoot it. If you hold the trigger and try to bounce shoot the nails, the driver will not...
The roofers that frequent my shop want their nailers to work like machine guns. Here is what I do to make the hitachi 45 nail fast. Remove the cylinder and sand the fine scratches where orings meet cylinder. I use a rubber slug with a small bolt through the center. The rubber slug fits snuggly into the cylinder and the bolt into chuck of drill. Turn the cylinder with the drill while holding fine sandpaper against the scratches untill smooth. remove the nose from body and replace the sheet (part # 877125) and the bumper. If the sheet fits loose on the driver and the bumper has cuts or missing pieces, the driver will not return with full force. also the oring on the piston should not be too tight. Just snug enough to hold the weight of the piston. While nose piece is off check the air passage to feed piston for trash, use a small wire and push through to make sure. Make sure the orings on the feed piston fit snug. Actually push the feed piston by hand in the nose piece to make sure the three orings fit snugly. A loose feed piston will reduce nailing speed. Finally replace the boot on the firing pin. If the boot is blown off its seat with use replace the firing pin. A loose firing pin will waste air and lower pressure reducing nailing speed. Good luck
Dec 01, 2008 | Hitachi NV45AB2S Coil Roofing Nailer
Tag Heuer TH 5104 Sunglasses Logo
706 people viewed this question
Top Tag Heuer Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Tag Heuer Clothing Accessory Expert? Answer questions, earn points and help others
