Question about Broderbund The Print Shop 21 Deluxe Full Version for PC
Why does the quality of my photos degrade so badly after putting them to graphics in Print Shop[ 21?
Posted by kevinandjosl on
nick hunt
    Sergeant:
  • 186 Answers
You may need a new or updated graphics card
Posted on Feb 01, 2011
What is the serial number for print shop 21?
It will be on the disc or in the manual. Unless it is a pirate copy
Jul 09, 2014 | Broderbund The Print Shop 21 Essentials...
I need activation code for The Print Shop Essentials 21 please...
To get the activation code for Print Shop Essentials do the following:
a) Send an email to their customer support and tell them about it. They shall look into it and shall send you a legitimate code for your Print Shop.
b) The other way around is that you download a cracked version or portable version of Print Shop Essentials. You can get them from either of these two methods:
i) Visit www.filecrop.com and search there.
ii) Do a torrent search and you shall find it for sure.
Oct 24, 2012 | Broderbund The Print Shop 21 Essentials...
Hello,after refilling ink cartridges HP21 and
Since HP’s ink technology is different from other manufacturers, they do not recommend to use refilled or remanufactured ink cartridges. Though the cost of genuine HP cartridges are bit expensive than the other cartridges, HP cartridges are manufactured in keeping mind the important factors print quality and customer satisfaction. Using the refilled cartridges may degrade the print quality and may damage the printer’s internal hardware.
I request you to use genuine HP Inkjet cartridges and verify the result.
:) Dr Tony
May 10, 2010 | Office Equipment & Supplies
UPDATE for windows 7.
Use Windows XP for better performance
Dec 11, 2009 | Broderbund The Print Shop® 21 Deluxe Full...
Linking photoshop and canon MP700 for best quality photos
If your pictures are shot at the highest setting on your camera, you should not have to do anything in Photoshop.
When you go to print make sure the print setting on the printer are set to the highest level.
Nov 09, 2009 | Adobe Computers & Internet
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Epson DX 8450 printer takes 5 mins plus to print 6x4 Jpeg photo
For more clarity (High DPI) print quality it will take time. For faster prints go to printer settings and select the printer and Right click on it select properties.
There in General TAB you will see at the bottom Printing Preferences Select that one.
There you will get some page tabs select Paper/Quality
Select Advanced and Set Graphic Print Quality lesser. The more you set the print will be faster.
Apply all settings and press ok.
This should solve the problem.
Thanks & regards
Nanda Kishore
May 09, 2009 | Epson Stylus RX580 InkJet Photo Printer
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
Broderbund The Print Shop 21 Deluxe Full Version for PC Logo
49 people viewed this question
Top Broderbund Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
