Question about Redfield Revolution Riflescopes
I have a Redfield 3x 9x riflescope with a bent horizontal cross-hair. It is an old scope I've had for years. I was wondering if it is covered by warranty? If so,where do I send it for repair?
Posted by jmemcc on
thomascha103
    Sniper:
  • 58 Answers
Redfield was purchased by Leupold in 2008, and is only able to repair and service Redfield scopes made in 2010 or later. If it was made before 2010, then it isn't covered by warranty, but Leupold does suggest contacting Iron Sight, Inc, if you want to ask about repairs and associated costs. Here's what the Redfield/Leupold website says:
When Leupold & Stevens, Inc.® purchased Redfield in April 2008, it did not acquire the capability to repair Redfield products manufactured prior to this purchase. The repair tooling and parts were purchased years ago by other repair services. Leupold & Stevens, Inc. will service its manufactured Redfield product (manufactured from 2010 forward) in accordance with its published warranty.
At this time, should a non-Leupold & Stevens, Inc. Redfield product require service, we suggest contacting Iron Sight, Inc. (918) 445-2001. This contact is provided for information purposes only, as Iron Sight Inc. is not affiliated with Leupold & Stevens Inc. They should be contacted directly for all information regarding repair, service and associated charges.
Posted on Feb 01, 2011
Manolito Mendoza
    Sergeant:
  • 236 Answers
Here you go.. Click on this LINK for Redfield's Support Number.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Which direction do you turn windage and elevation
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 22, 2011 | Tasco 22 Riflescope
My bsa sweet 17 6-18 is shooting about 2 inches high at 100 yards. on the adjustment turret it has an arrow that shows which way to turn for up. What is moving up? the point of impact relative to the...
Jun 02, 2011 | Bsa Optics Sweet 17 Target Riflescope...
Why does my 30 yr old redfield, widefield ,range finder accu-trac scope that has operated great for all these yrs, now I cain,t get it hit in the same zone a target. The rifle is clean and operates great...
well if the bullet hit is jumping about its all down to your scope,,,it could be that its just "lose on its mount!" or its died on you,,like the cross hair is bouncing about inside the scope so with the recoial it jumps into a new place with every shot fired there by giving you a new point of impact,,,
this can happen if the scope was wound right up or down or left or right and strain was put on the adjusters,,,you may need to buy a new scope,,,,a good "air rifle!" scope will work quite well on most full bore rifles,,,yer right i here you say!!! ok,,iv got air rifle scope's on my .303 + 7.62 + 22-250 + .357 under leaver marlin cowboy, all 3 of my .22 rim fire's and they have been on these rifles for years now,,,1000,000, of rounds fired so far, with no problems! and no drifting so far,,,
an air rifle scope is very strong you know,,,but they only cost £150,00p or less for a good one?????
ps,,,,dont buy a tesco scope there cra*y
Nov 22, 2010 | Redfield Optics
My 3x-9x.40 scope shoots low and to the right,what does one click on elevation and wind represent?
Most scopes of this type move the bullet impact 1/4 inch at 100 yards, or 1/4 minute of angle.
Sep 19, 2010 | Tasco 3-9x40 World Class Riflescope 30/30...
How to use the BDC on my rifle scope
  1. Step 1 Take a rifle with a properly installed BDC bullet drop compensating reticle to a rifle range. Using ear protection zero the scope reticle so that the point of impact corresponds to the center of the cross hairs at the distance you have selected - typically 100 or 200 yds.
  2. Step 2 Determine the trajectory of the specific cartridge you have selected. There are several ways to do this. Ammo manufacturers publish trajectory and wind drift information. There are web based ballistic calculators like http://www.biggameinfo.com/BalCalc.aspx which will tell you how much your bullet drops at known distances.
  3. Step 3 Scope manufacturers like Leupold can be a valuable source of information about their reticle: "Leupold® Ballistic Aiming System: Boone and Crockett Club® Big Game Reticle aiming system provides a series of additional aiming points to improve your ability to shoot accurately at longer ranges. Nikon2_bing.gif also provides good information suggesting the marks on their reticle be used for zero at 100yds followed by circles below representing 200, 300, 400 and 500 yds if the cartridge travels around 2800 ft per sec. Nikon suggests the center cross hair be zeroed at 200 yds for magnum calibers traveling around 3000 ft per sec. We understant that each variation of different bullet weight and powder charge changes trajectory and a scope manufacturer can not build a different reticle for each different cartridge made so practice on the range to determine how well the marks relate to the actual impact of where your bullet strikes at a know distance is important. The one thing that people using BDC scopes typically have problems with is that a BDC scope has the reticle in the second focal plane of the scope. If the reticle was in the first focal plane of the scope the reticle would look smaller on low powers like 3x and grow proportionately larger as the power increased to say 9x top power. The problem is that while the marks on the BDC reticle correspond accurately to the bullet drop at the know distances 200, 300yds etc. What happens when you lower the power from the scopes maximum power to any other lower power is the reticle stays the same size and the field of view within the scope increases which means that the distance between these marks on the BDC reticle no longer corresponds to the point where the bullet will strike. In short BDC reticles only work at the maximum power of the scope or at a set specific power. At all other powers these BDC reticles do not accurately represent where the bullet will strike.
  4. Step 4 The center X always remains the same. If you zero at 100 yards and you know that your bullet drops 8 inches at 300 yards you could forget about the BDC marks and hold the center X 8 inches high - that works at any power 3x or 9x and should be used at lower powers. If you zero the center crosshair at 100yds and have the BDC scope at the maximum power 9X then the first line or circle below the center X should be the mark you place on the center of the 200 yard target----- the bullet strike should hit the center. If by some chance you put the scope on 3x and placed that first mark below the center cross hair on that 200 yard target you would shoot over the top of the target. This is because as the power of the scope decreases the field of view increases the angle increase and gets wider. You can experiment with known power settings and see at a specific power say 3x what that first circle down corresponds to and make notes because at any set power what the marks correspond to will be repeatable.
I got this from a website, hope it helps.
Apr 08, 2010 | Hammers Air Gun Rifle Scope 3-7x20 With...
I NEED TO IDENTIFY A SCOPE.IT IS A REDFIELD WITH OVAL EYEPIECE AND ROUND FRONT.IT HAS A DIAL ON TOP THAT SAYS UP WITH AN ARROW.IT IS 12.75 INCHES LONG.ALSO HAS A DIAL ON EYEPIECE END THAT GOES FROM 3 TO...
The best guess I can make using my books going back to 1970. Cant be sure of the dates they started, but about 1980 Redfield made what they called, Widefield low profile scopes. They made 7 of these Widefield scopes, 3 Variable power wide view and 2 they called Accu-trac Varable these 2 are in 2x-7x power and 3x-9x power the Accu-trac scope is the one you have I believe.
Nov 16, 2009 | Optics
Not a problem but need operation instruction for my scope.Its a tasco pronghorn 3x9x40 with adjustable yardage and has two elavation cross hairs,I have had it for many years and it works perfect,but I have...
I believe the second cross hair in your scope relates to an 18 inch dimension, or that of a deer. When you adj the wire to the body of a deer, it will be the distance, I'm not sure if you have to do the math, or the scope does it for you. Some scopes, you had to figure the hold over by the distance in the scope. others would be set to shoot at that distance. I would ave to look that one for you to be sure, but that is the idea. Hope this helps.
Nov 11, 2009 | Tasco PH39X40D 3-9x40 Pronghorn Riflescope...
Bent tube
Is it bent or is it a dent? If its a dent no biggy, it should work ok, may even put a good mount over the dent and tighten it to take it out. If bent it may still work good enough to hunt with and you will not fear it getting bent again. You will loose a bit of Viewing area at far distances, and the cross hairs may seem out of center, with dark area to the bent side but should still work.
Oct 25, 2009 | Redfield Optics
Cap cover pentax 3x-9x scopes
You do not define "cap cover" as to whether it is a 'lens cap' of which the Objective Lens comes in varying sizes with the 3x9 scope depending on the model.
However, you should be able to find one in the size you need at most any Firearms supply store. I have even found a lens cap for a Leupold at a Walmart.
Barring that, go to; www.pentaxsportoptics.com, they should be able to help you in your quest.
Good luck. :)
Apr 14, 2009 | Pentax 3X - 9X 40mm Lightseeker XL Glossy...
Crosshairs are cocked to the right.
your scope has spun in the scope rings. Loosen the screws holding the scope to the rifle and turn scope until crosshairs are into position. Then tighten screws. You will need to sight in again. If it keeps moving replace scope rings.
Dec 12, 2008 | Tasco 3-9x40 World Class Riflescope 30/30...
Redfield Revolution Riflescopes Logo
516 people viewed this question
Top Redfield Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Redfield Optic Expert? Answer questions, earn points and help others
