Question about Sony Cyber-shot DSC-W170 Digital Camera
When I turn the camera on, the lens goes in and out several times. Then the message comes "turn the power off and on again". I tried taking the battery out, pressing the power button for 15 sec etc., but this doesn`t help. Is there anything else to do ?
RAJDEEP DUTTA
  • Sony Master
  • 2,517 Answers
Hi there this is Lens guide pin problem. 99% chacHi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated e is replacing the lens. but before that try these below.
Posted on Feb 01, 2011
  • RAJDEEP DUTTA
    RAJDEEP DUTTA Feb 04, 2011
    I think the problem did not solve. You need to replace the Lens. Thats only the solution. Thanks.
I bought a Panasonic Lumix DMC-TZ7 via Amazon in July 2010 - it has been working fine up until this weekend. When I turned the camera on the Zoom extended to full length. It then comes up with the message...
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Sep 06, 2011 | Panasonic Lumix DMC-TZ7 Digital Camera
When powering on, the camera lens pops out and back in four times, then displays the message "Turn the power off and on again." It continues to do this every time I turn it off and back on.
Try a battery pull or new batteries. Take memory card out. If it doesn't work. Call the manufacturer. They may be able to send you a new one if it's under warranty.
Mar 12, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
I dropped my camera. In the off position, the lens stays open and projected. Then turning to the on position the lens goes in, then out again. Then I receive the message "Please turn camera off and...
Hello
Regards
Andrea
Feb 15, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Lens goes in and out and error message 'turn
this message comes up if you have dropped your camera. try tapping the device while the message comes up. if that doesn't work then you have to take it to the sony service centre to replace the lens array. it costs about 60$ to replace it.
Jul 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Error message, cant take pictures
Camera needs to be serviced. This is a common problem with sony cameras. If you have any knowledge of electronic, you could take apart and clean and lube lens. If not sony will fix for a fee, go to the sony web site, they offer a repair service. This happened to mine, it cost $95 plus shipping costs to repair. Now it works great, for how long who knows.
Jul 17, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Message "turn power off and on again"
Your camera has dirt in the lens, you need to get someone to take camera apart and clean it. This is very difficult to do if you dont have any knowledge of cameras. You could send to sony, they will repair, around $95 plus shipping. Kind of expensive. Cheaper to buy new camera. But you have nothing to loose by trying to take apart clean and lube lens.
Jun 18, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Lens go in and out several times, then I got message to turn off
I have faced same message "Turn the power off then on again" today.I tried to on-off several times.finally I discovered that lens is so dirty.when I cleaned the lens it come alive :)
Apr 06, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
