Thermador PRG484GGUS Gas Kitchen Range Logo
Posted on Feb 01, 2011
Hi, My Thermador stove is broken because of the rear right valve (part PRG484GGUS, serial#20030168). Do you know where I can find this part? I'd appreciate your insight. Suavity
ComptrGuru
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Jun 08, 2014
ComptrGuru
Contributor
Level 1:
Welcome Back:
Answers
11
Questions
0
Helped
4208
Points
15
Thermador parts are all made by Bosch. Look to a Bosch parts supplier for help and the part.
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
What is the difference between duel fuel or gas..? Does one allow you to change grill to griddle?
"Dual fuel" normally indicates that the appliance can use either natural gas or propane.
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
I have a Thermador PRG304US. The far right burner
I am having the same problem. Have you found any solution?
Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Could you tell me what year this model thermador gas top 6 burner
Thermador PRG stove is build between 2001-2003, $5, 000 new.
depends on the condition of the stove, and the oven. of cause, it is hard to say how much without testing it out. It is like buying a car. need test drive.
Thermador model RDF30RS burners won't light
Hi, there are two small circuit boards on those burner controls. They are called potentiometers. There was probably a boil over or spill at some point. They are notorious for failing. Hope that helps.
Thermador oven parts
I have a Thermador oven where the inside window glass is broken. Are there any parts available for a
model #14-33-754
30 "?
[email protected]
Top Thermador Kitchen Ranges Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
