I need new batteries on my scooter ?
Take your batteries out, and take them down to .a battery shop. Have the battery load tested, Reading the voltage under no load conditions will not tell you much, normally the batteries voltage gives you it state of charge. These batteries will show a full charge at no load, as soon as you put any load at all on the voltage drops off and you don't have much in amperage output. The amperage is what is important when you right down to it. When load testing your battery they will use an instrument that they punch in the cranking amps. The instrument will look for the voltage drop off at a load of what ever amp value you punched into the instrument. The instrument will give you a pass\fail indication for the cranking amps value the technician punched into the keypad. There can be a problem when load testing batteries. The technician doesn't key in a amperage value, This is what happened to me. The instrument when no value is entered will use a default value, Say the default amperage is usually set at around 200 Cranking amps. My technician was either rushed or just being lazy. He set the load tester to use the default values, my battery passed with the tester set up the way it was. My battery is a 35 amp\hr battery and puts out 480 cranking amps In actuality my batteries weren't putting out nearly that much. It would put out 265 cranking amps for about 2 seconds then die. He told me the batteries were good. When i brought the batteries back to him
i didn't let him take them into thee back room. THIS TIME HE DID THE CHECKS OUT IN PLAIN SIGHT OF ME. I asked to do a comparison between my batteries and new ones. We had to retest a number of time in order to find the upper limit of the new batteries. As it turned out my batteries were bad and all my problems disappeared with my old batteries. NOTE, scooter use deep cycle batteries only Glass mate batteries if you want to take your scooter on a flight. Hope this helps
