Open the front panel, remove heat exchanger and clean. also clean out lint tray.
this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
I have the same problem I have to reset the button every time we use it also we have cleaned the dryer of all lint anyone know what else would make it stop heating I would never recommend a Bosch dryer or washer they have given us nothing but problems our washer door fell off last month we paid top dollar for these machines and I am ready to throw them out the door!
