Question about HP Photosmart C4280 Aio Printer
Have HP C4250, I need print cartridge numbers. Lost cartridges.
Posted by marydominick on
rumorbill
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
Cartridges use are HP74, HP74XL BLACK.
HP75, HP75XL COLOR.
HP99 PHOTO
Posted on Feb 01, 2011
What ink is used in an hp q1660a printer?
Here is the Information that you are looking for.
Ref Link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00691&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=90764#jumptocontent
Inkjet print cartridge part numbers
Inkjet print cartridges Part numberHP 56 Black Inkjet Print Cartridge C6656A HP 57 Tri-color Inkjet Print Cartridge C6657A HP 28 Tri-color Inkjet Print Cartridge C8728A
Feb 18, 2013 | HP Q1660A PSC 1210 All-In-One Printer...
I replaced the cartridge for my HP C4250 printer/scanner but the alignment page did not print properly, so I did not get a proper scan page. Now it will not print at all. What next?
A cleaning will fix the problem. To clean your HP C4250 > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
hope this helps, thanks!
Sep 30, 2011 | HP Photosmart C4250 Multifunction Photo...
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Why does my hp photosmart C4250 all in one printer keep texting that my color ink cartridge is missing. It is not missing. I recently replaced it. This action is causing my printer not to print.
hello, i've had a few of these in the shop with same type problem, after trying many cartridges, the only thing i came up with, some of these cartridges that are xl's, they seem to fail more, but normally, brand new hp branded cartridges work, the refills are a hit and miss, and ones refilled at costco seem to fail almost as soon as put in.
Sep 23, 2010 | HP PSC 1315 All-In-One InkJet Printer
What ink cartridges do I need for Model C-3180 ? I lost my manual
1) Just go to any online cartridge supplier, follow their links to your printer and they'll tell you.
2) Is it not written on your current cartridges ?
3) Normally most printer manufacturers print the cartridge number on the access door.
4) Go to the HP website, follow links for support and downloads, download a copy of the user manual for your printer.
May 03, 2010 | HP Photosmart C3180 All-In-One InkJet...
HPPhotosmart C4250 mgs "Printer Cartridge missing or not detected
There may be debris that is blocking the communication between the cartridge and the printer, especially if you are using a remanufactured cartridge. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
Mar 15, 2010 | HP Photosmart C4280 Aio Printer
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
Install cartridge missing on Deskjet 6940
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | HP Deskjet 6940 InkJet Printer
Changing printer cartridges for HP Photosmart C4250 All-in- one
Pictures and Step-by-step here
  1. Open the print cartridge door.
  2. Remove the old cartridges, they will move into a position you can reach automatically.
  3. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  4. Open the packaging and remove the tape from both cartridges.
  5. Hold the cartridges with the HP logo on top.
  6. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot .
  7. Push the cartridge firmly into the slot until it snaps into place.
  8. Close the print cartridge door.
Hope this helps.
Jul 30, 2008 | HP Office Equipment & Supplies
HP Photosmart C4280 Aio Printer Logo
104 people viewed this question
Ekse
efs_perpends
efs_perpends
