Question about Denon AVR-1508 Receiver
Hi, some days ago my little daughter messed up with all possible buttons on the front of the receiver and the remote also, so in result I have the follwoing issues: - when I try to set the speakers with the Audigy hardware they start to make strange popping very loud sounds and I cannot finish the process - when I start the test tones programm the speakers make very loud noises and I am forced to turn them off - the DTS and DOLBY settings aren't working, I can use only stereo TV - most of my inputs (optical - DVD and VCR, where I have connected my PS3 and PC) aren't working Please give me advice how to proceed - the standard reset with power off+A+B is not working
Posted by ktraev on
Sean534
    New Friend:
  • 9 Answers
Erm.... this is a strange one, the popping very loud sounds is the amplifiers turning on and lookinf for the input, so its possible the input method has been altered from original settings i would try fixing this first, im sorry i cant be any more help or any help at all to be honest lol, worst case scenario put your daughter in front of it and let her play away again. good luck : )
Posted on Jan 31, 2011
Echostar remote changes channels slow and changes guide without touching remote
Hi there, Cheri Torres with DISH Network Customer Service here. It sounds like you could possibly be experiencing UHF interference. UHF interference could possibly be caused by someone in your area with the same remote frequency as you or possibly by other electronic equipment in your home. The best way to fix this issue is by changing the remote address on for the remote with the issue. I will list here for you the instructions for readdressing your remote. I hope you find this information useful and if you have any further questions feel free to email me directly at [email protected] or respond here and I would be happy to help!
Instructions for readdressing remote
  1. If you are using TV1 remote stay at the receiver location if you are using TV2 remote take that remote to the TV1 location where the receiver box is.
  2. Go to System Info screen. You can do this by pressing the system info button on the front of the receiver box or by pressing the power button once then pressing the channel up button once on the front of your receiver.
  3. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2).
  4. Hold down the SAT button until all mode lights light up.
  5. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number in the little white square to something than what is already listed.
  6. Press the pound (#) button
  7. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 5 will appear in the System Info screen under Remote Address.
Mar 03, 2011 | DISH Network IR Remote Control
I have a dell dimesion 3000 with a moniter that came with it from dell. a little while ago my nephew was messing with the moniter and made it really blurry. is there any way i can fix this?
There should be a menu button, and once in the menu, I believe there should be a Factory Reset Setting that you can choose and it should clear it up. If that does not work, the monitor could possibly be damaged and the blurry screen is the result. Good luck. Thanks. -Sa_Les_Ski
Feb 26, 2011 | Dell Dimension 3000 PC Desktop
Sat button lights up and remote will not function
Hi, my name is Cheri Torres with DISH Network Customer Service I came across your post and wanted to see if I could help. It sounds like your remote may need to be readdressed to your receiver box. I will list here for you the instructions on readdressing your remote to your DISH receiver. Another thing you may want to check is the batteries, make sure they are in the remote correctly and that they are fresh batteries. If you have any further questions or concerns post back here or email me at [email protected] and I will be happy to help! :)
Instructions for addressing remote to receiver
  1. Go to System Info screen. You can do this by either pressing the system info button on the front of the DISH receiver box or by pressing the power button once and the channel up button once on the front of the receiver. You may need to open the little door on the front right side of the receiver to locate the buttons.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote. Change the number to something different then what is already listed in the white square.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Jan 20, 2011 | DISH Network IR Remote Control
Hi! Plugged in VSX 04 (newly arrived from Ebay),
No, but is is possible it is not designed to work without speakers connected. Some amps will not last long if the outputs are run "open circuit".
Apr 20, 2010 | Pioneer VSX-04 Receiver
My remote fell 5 days ago and now my tv can gon on but it has a little padlock on the top right hand corner and I can only switch the tv on or off
off the tv and while you on it just press all the buttons on the tv front pannel randomly after tv gets on, if not solved.then off the tv after you on it again.just press the volume up and down button together on the remote or at the front pannel of tv. if still not solved   off the tv and on it and press the channel changing front and back button together. if still the same problem then  off the tv and as you on it press the  ---F --- function button in the remote and --- MENU ---  button in the remote togetrher  for 1 minute.
Mar 09, 2009 | LG Televison & Video
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
I lost my remote, but I need to use the A/V.. Is it possible?
hook up the a/v color coded cords on the back then without a remote hit the dvd button on the front its should have you ready to play.
Sep 04, 2008 | Insignia NS-13CTV
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Receiver misinterpreting IR signals
There can be a few causes of this. Since it happens with a number of remotes, we can state that the problem is inside the receiver. In the front of the receiver (inside) you should see a small silver box. Inside that is the InfraRed receiver. This is a 3 pin device. Check to be sure that the pins have good solder joints. A bad joint can cause problems. Also, after the receiver comes what is called a digital switch. This is similar to a transistor except that it makes the transitions more steep, like a step rather than a ramp. If this part is bad you can get these results. The digital switch will be marked c124 (perhaps or somehting close).
Check these out and keep us posted.
Dan
Apr 09, 2008 | Sony STR-DA3ES Receiver
Mitsubishi va-50111 television
You have to hold the menu button for about 8 seconds. You'll get a sign at the bottom of the screen that says "Front Panel Lock Disabled"
May 04, 2006 | Mitsubishi VS-50111 50" Rear Projection...
Denon AVR-1508 Receiver Logo
126 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
