Question about Taylor Kitchen Scale – (6 lb) ()
Err code on 3841B Digital Glass Kitchen Scale
Posted by j_sbarnes on
1helpful
Propert bathroom scales does not work after changing battery. keep getting Err message
Check that the battery is in the correct way. Reset the machine after you check battery.
Need manual for camry ek2052 kitchen scale, gives err messge. Already replaced the battery
WARNING INDICATORS
1." Lo" Replace Battery
2. "err" means that scale is overloaded
1helpful
My Salter model 3003 kitchen scale shows Err when I turn it on. How can I fix this?
This means that it cannot calibrate itself because the sensor is out of range. This can happen if you drop it or overload it. Check the feet on each of the for corners and make sure they are not stuck, you can do this with the unit on and see if it registers any force on the pads when you press and release them or use a screw driver to lift them SLIGHTLY. There are a lot of youtube videos on how to check and repair them.
Replaced batteries and scale does not register weight, but just races through numbers and then "Err."
I have same problem with my scale. New batteries work for a few days. I'm throwing this thing out.
Keeps showing err. Thinner scale
Tap the scale twice with your foot so 0.0 appears first, then weigh yourself. If you step on the scale before 0.0 appears, the scale will not function properly.
2helpful
HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
1helpful
Err message
The "Err" problem is a very common one but no one so far could predict the reason causing this.It means that there has been an
error in the scale measurement.The only solution mentioned everywhere is to Step off the scale until its LCD screen blanks and Step back on the scale.
2helpful
2answers
Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
16helpful
5answers
Watchers WW-87 Body Fat Glass Scale
Hi
At this web site bottom left hand corner there is an instruction manual
http://www.conair.com/weight-watchers-glass-digital-scale-p-667-2_60_38.html
Taylor Kitchen Scale – (6 lb) () Logo
Top Taylor Health & Beauty Experts
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
mark woodring
mark woodring
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
