Question about Pioneer DVR-RT500 DVD Recorder/VCR
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
Posted by paul_osbourn on
howkau
    New Friend:
Hi general finalization is achieved by pressing setup button (right lower) on the next screen (setup menu) scroll to system setup and press. On submenu scroll to disc setup and press.Next submenu (disc setup) scroll to finalize and press proceed and on next menu press tes to finalize and wait tas this may take some time.
Posted on Jan 21, 2012
ronthekanuk
    New Friend:
    Problem Solver:
  • 8 Answers
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Posted on Jun 30, 2011
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
My dvd player plays dvd discs ok. but when i use dvd burned on my computer shows no disc.the same disc plays fine on my computer
Some DVD and Blu-Ray players will not play a burned disc until it has been finalized. Finalize the disc on your computer then see if it will play. (Finaalizing a disc means it can no longer be recorded to, by the way.)
Aug 27, 2011 | Samsung BD-P1500 Blu-Ray Player
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
I burned a dvd in Pinnacle Studio Plus 11. I know stuff burned to the DVD, but it won't play on the computer or in the DVD player. Does Pinnacle not finalize the DVD, could that be why it's not playing? ...
Be sure to check if there is a file written on the DVD disk. Try to install a player like VLC and see if the .VOB file is playing.If not the DVD is not burned properly then try to recheck your settings on the Studio 11 Make Movie
Sep 13, 2010 | Computers & Internet
Windows media player burned a dvd for me now when i tried to play it on my dvd player it wont work what do i do it says disc is not finalized please finalize the disc on the recorder which was used for the...
Most DVD player can't read open session discs, meaning when you burn your DVD movie there's an option there that when your disc is not full you can still add files on it, it's open session, in your case if you want to play it on dvd player you must select the finalize the disc to close the session and you can play it in any dvd player you want.
Oct 30, 2009 | Microsoft Windows Media Player
I have windows vista the dvd-rw that i burn does not play on dvd players
Not all DVD players will play rewritable DVD disks. Check for compatibility. Also, burned DVD's need to be "finalized" and the region code of the burner must match the player. Check your software docs for steps to finalize and setting your region code. If you are in the U.S. your region code is 1.
May 31, 2009 | Gateway Computers & Internet
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
DVD+R will not play
2 Things 1 You need to Finalize the disc to play of a DVD player check that out with your DVD burn program. 2 Check the DVD players capability with certain discs, not all payers will run 'burned disks' sometimes even the brand of disk matters or whether it is + or- type There are may variables with the DVD firmware. Finalize first the the first step.
Jul 31, 2007 | Emerson EWD7004 DVD Player
Pioneer DVR-RT500 DVD Recorder/VCR Logo
281 people viewed this question
Top Pioneer Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
