Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Do i have to hook up my refrigerater to the sink to get water an ice
Posted by arciniegasna on
techomecho
  • 430 Answers
Yes you have to connect the water pipe from sink to refrigerator back.hen turn ON the water valve o run the water from fridge to freezer section.Form freezer section to water inlet valve at the back of ice maker.Then only ice maker and water dispenser will function.Other wise only freezer and fridge will work.-------------- If you dont have water tube and water valve then You can get required parts from www.repairclinic.com or from online sears part site. If you are not aware of how exactly to set and connect water valve and water tube then local plumber or fridge repair technician can do it for you.Its not at all hard job and can be easily done.It will take near to 15 minutes to connect all parts.------------- Thank you.
Posted on Jan 31, 2011
Scotsman ice machine
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
1helpful
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
No water is coming out of the water depenseron the refrigerater
does your ice maker work OK ? if yes , do you have a inline water filter in the upper right hand section of your refrigerator at the rear ? if yes , replace the filter and follow the directions on the new filter to properly prime the water dispenser line. if the unit will not prime with the new filter installed, you'll probably have to replace the water dispenser control valve located at the bottom rear of the refrigerator where the main supply water line goes into the refrigerator.
1helpful
Ice maker water inlet keeps running
Replace the water inlet valve. It's on the back where the water supply hooks.You can turn the water off usually under the sink.
How do i hook up fridge to sink so we can have water and Ice
Ice Maker Kit comes with a self tapping saddle valve.
Icemaker is leaking into ice bin.
it sounds like the water valve is leaking
1helpful
Ice tastes funny all of a sudden.
you need to throw out the ice. ice gets stale after a couple of weeks , so toss the old ice. also is there something like garlic or another food that has a strong oder uncovered in your refrigerator section? air flow covers all of the unit, both refrigerator and freezer sections. if your refrigerator is not smelly , put an open box of arm hammer baking soda on a shelf in both sections of the refrigerater. if water and ice still taste funny shut off water supply and check the filter at the rear in the lower part of the unit. take off connecter and visibly check the strainer in the water valve,clean it out by removing it and rinsing it under the sink faucet. make sure that water from other faucets taste ok . the only thing left is to flush out the water tank by filling up glasses of water until the water gets room temperature . that's about all you can do short of replacing the water line leading to the refrigerator, although i have never had to do that before. good luck
Hose from door dispensor hook to refrigerater
it should hook up to a water line with a coupling at the bottom of the freezer door. take the kickploate off and then look underneith the refrigeraqtor and there should be a clear plastic tube there3 to hook up to.
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
