Question about Kyocera FS-2000D Laser Printer
Hi have an error call service 6000:0085594 My printer is Kyocera Fs-2000D If you can help me pls
Nikolay Boychev
  • Kyocera Master
  • 525 Answers
Code: 6000
Contents: Broken fuser heater lamp wire
30 ppm model:
The temperature does not rise 1×C after
the fuser heater lamp has been turned
on continuously 5 s.
35/45 ppm models:
The temperature does not rise 1°C after
on continuously 10 s during waming-up
or at standby.
Causes:
- Poor contact in the fuser thermistor M connector terminals.
Check procedures/corrective measures:
- Reinsert the connector
Causes:
- Fuser thermistor M installed incorrectly.
- Check and reinstall if necessary
Causes:
- Thermal cutout triggered.
- Check for continuity. If none, replace the thermal cutout
Causes:
- Fuser heater lamp installed incorrectly
Causes:
- Broken fuser heater lamp wire.
Check procedures/corrective measures::
- Check for continuity. If none, replace the fuser heater lamp
Posted on Feb 21, 2011
Hi, I have an ecosys fs 2000d, with a call service message 6000:0026965, somebody help me please
Call service message 6000 in Kyocera is a fuser error code. The fuser must have gone bad.
Regards,
Shrey
May 31, 2011 | Kyocera FS-2000D Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
I have a kyocera FS-2000D with error code: Call for SErvice 0150:0000049. Help...thanks in advance
0150 is a problem with either the engine board or the EEPROM chip that sits on the engine board. If you want to do it yourself, you can open the printer up and reset the chip on the board as well as reset all of the connectors that plug into the board. Otherwise, your best bet is to call a Kyocera service technician.
Mar 17, 2010 | Kyocera FS-2000D Laser Printer
CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Apr 14, 2009 | Kyocera FS-2000D Laser Printer
Kyocera fs-2000d printer
A KYOCERA-MITA technician has to upgrade the firmware.
Jan 31, 2009 | Kyocera FS-2000D Laser Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Regardin kyocera FS-2000D
The files called 2000sys.zip & 2000_eng.zip I beleive, if that helps. I bet after you have updated the firmware, you will find the serial number absent from status page, muz get corrupted when the engine firmware chucks the 150 error, Just thought I'd say although is not norm a problem
Oh, It only ever does the 150 once, never if firmware is updated.
Nov 12, 2008 | Kyocera FS-2000D Laser Printer
ERROR CODE 7410:0004729
Hi, switch off printer ,just open cover(door) on the left side of the machine and push Drum Unit in machine(to proper seat)
You have to hear "click" sound.Switch on printer.
Regards...
Mar 08, 2008 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D Laser Printer Logo
298 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
