West Bend 82306 Stir Crazy® Popcorn Maker Logo
Posted on Jan 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size is the popper 6 or 8 qts - West Bend 82306 Stir Crazy® Popcorn Maker
Lance Hill
Level 3:
Genius:
  • Master 1,739 Answers
  • Posted on Mar 25, 2011
Lance Hill
Master
Level 3:
Genius:
Answers
1739
Questions
Helped
800569
Points
4235
The West Bend 82306 Stir Crazy® Popcorn Maker ca be either 6 or 8 qts.
The 6-qt model has a rounded domed shape as per the picture above; the 8-qt model has a straight-sided top.
The User Manual can be found here:
http://www.westbend.com/supportdata/L5557B_StirCrazyPopper_ALL.pdf
1helpful
Problems with weed poppers
Garden weasel has metal handles and fiberglass. Fiskars have wooden handles and fiberglass handles. and i beleive garden weasel have more options such as handle lenghts, size. ect..
Popcorn popper 50030178 I found this old popper like my nanny used to use. But I don't know how much popcorn or oil to use can you help me. I have the measuring cup lid all the parts with it.
What type of popper is it? The 50030178 model isn't one I'm familiar with.
For most of the small air poppers, such as the Presto Air poppers, fill the measuring cup lid with popcorn so that the popcorn is level with the top of the cup. Add this amount of popcorn to the popper. On those units, there is a fill line inside the popping chamber. Do not fill past the line. For these air poppers, if you want to have butter or margarine on the popcorn, add 3 tablespoons of the extra to the lid after you replace it on the popper.
For the Hamilton Beach Hot Oil Poppers, the manual for the 73300 is available here: http://www.hamiltonbeach.com/use-and-care/use-and-care.php . Fill in the type of device and then the model. The amount of oil and popcorn will depend on how much you want to make. For a single serving, you need 2 T (tablespoons) of kernels and 1 - 1 1/2 t (teaspoon) of oil. For enough popcorn for a family, you should use 1/2 cup of kernels and 1T of oil. http://useandcares.hamiltonbeach.com/files/840190701.pdf has a full chart of the amounts on page 6.
I hope this helps. Please add a comment with the brand of popper and I'll check for a specific chart for that unit.
(It's been a while since I used the air popper that I used to have.)
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
10helpful
2answers
How many quarts of transmission fluid does it hold
You didn't state what size engine you have.
The 2.2 engine----- 6.9 qts.
The 2.3 engine-----7.4 qts.
The 2.4 is 7.4 qts.
The 3.1 is 7.4 qts.
The 3.4 is 6.9 qts.
These are the capacities for refilling after being drained.
2helpful
The manual got missed placed can you tell me the amount of kernnels to use in it. It is a six qt. stir crazy popper
USING YOUR STIR CRAZY® CORN POPPER
Place popper base on flat, dry surface. The heat-resistant base allows for safe table use.
Preparing Popcorn
There are two models of the Stir Crazy® Corn Popper, one for making up to 6-quarts and the second for making up to 8-quarts of popcorn. Listed below are the proper amounts of oil, corn and butter (or margarine) to use for making various amounts of popcorn. Do not attempt to make 8 quarts of popcorn in the 6-quart model.
Quarts of Popcorn
Amount of Oil
Amount of Corn
Amount of Butter
1 Tablespoon
⅓ Cup
1 Tablespoon
2 Tablespoons
⅔ Cup
2 Tablespoons
6
3 Tablespoons
1 Cup
3 Tablespoons
**8
3 Tablespoons
1¼ Cups
3 Tablespoons
Here is the link to download the manual: http://www.focuselectrics.com/supportdata/L5557B_StirCrazyPopper_ALL.pdf
6helpful
Tranny fluid capacity 95 F150 5.0
Automatic trans??? 2 or 4 wheel drive??
AOD 2 wd- 12.3 qts
AOD 4 wd - 12.3 qts
C-6 2 wd - 12.0 qts
C-6 4 wd- 13.5 qts
E40D 2 wd 15.7 qts
E40D 4wd 16.2 qts
4R7OW - 14 qts
2helpful
3answers
How much transmission fluid does a 1999 subaru Legacy BH need
automatic trans 2.2liter engine- 1990-1993/ 8.8 qts.
1994-on/ 8.4 qts
2.5 liter engines 10 qts. all years
manual trans 2.2 liter 2wd 1990-1994 3.5 qts
1995 2wd 3.7 qts
4wd 1990-1994 4.2 qts
4wd 1995 on 3.7 qts2.5 liter aall years 3.7 qts.
Top West Bend Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
