Canon imageCLASS D661 Digital Printer Logo
Posted on Jan 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What causes my copier pages to have black smudges on them.
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Jan 31, 2011
Anonymous
Expert
Level 2:
Answers
71
Questions
0
Helped
11943
Points
197
Black smudges are usually caused by a defective or worn out drum. When the drum gets a fingerpirnt, any kind of oil, or anything else that causes the static charge to not hold the toner to the paper, the toner will not go where it is supposed to in order to create the image on the paper and it will cause smudges, streaks or lines.
3 Related Answers
Anonymous
  • 94 Answers
  • Posted on Aug 11, 2009
SOURCE: I'm getting black smudge marks on copies. After
open priter case and clean the caterigde properly,
Muggs01
Muggs01
  • 72 Answers
  • Posted on Jan 16, 2009
SOURCE: Small black circle smudges down center of printed page
try replacing the toner cartridge if that does not help it may need a fuser replaced
MalKontent68
Stan
  • 748 Answers
  • Posted on Dec 29, 2009
SOURCE: Canon i560 prints a black smudge pattern on left side of page
There must be some small piece of paper or paper dust buildup near the left side of the paper feed/press mechanism under the printheads.
Open the cover and inspect the far left area along the line of head travel - there often is a metal plate with small wheels that stabilize the paper, and under that plate look for some foreign objects. Try gently removing them with a toothpick - it is soft enough not to cause any damage, and also will soak in any ink residue that might be left there.
4helpful
Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
1helpful
2answers
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
When using it as a copier it prints a black line down the page, how do i fix this?
You need to clean the scanner glass. Even just a minute smudge can cause a line to go down the page.
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Too much toner on paper which then smudges
Try reducing the print resolution using the menu buttons. Does it smudge with coloured prints? If so then the fuser unit is faulty. If it is only black that smudges it is likely to be the K Developer unit. Ensure that you are using genuine toners, not refills or third party as the quality of toner can cause similar results.
2answers
Black smudge on side of paper when printing quanities
Hey, Pleas check Black imagine unit,if needed change it.
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
old marine
old marine
ZJ Limited
ZJ Limited
