Question about RIM BlackBerry? Curve 8330 Cellular Phone
It says Reload Software: 513 - RIM BlackBerry? Curve 8330 Cellular Phone
Posted by dominique_sw on
Udhaya Rajan
    President:
  • RIM Master
  • 1,932 Answers
After the maximum number of password entry attempts is exceeded by supplying incorrect passwords, and the BlackBerry smartphone is restarted, the following error appears:
The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone
Steps how to reload can be seen in below website
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB11320
Thank You
Posted on Jan 31, 2011
5 Related Answers
Anonymous
SOURCE: need to reload software 513 blackberry
i have a blackberry stom and it is saying reload sofware 513
Posted on Sep 02, 2010
Anonymous
  • 10 Answers
SOURCE: how do i reload software 513 for my blackberry storm.
What you need to try to do is reinstall the blackberry OS (operating system) on your device.
Assuming you have verizon
First install Blackberry desktop manager it should be in the CD that came with the phone.
If you can't find it download it https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=5E695511C1F9656B8E3E63DAB060F469
Then download the OS software for your phone http://vzw.smithmicro.com/blackberry/download.aspx?ct=personal"
Install it
Connect your phone to your computer and start Desktop manager
Click on application loader, on update software click start, click ok on USB pin selection.
when you get to the device backup and restore options, click settings and make sure backup options box is unchecked and device data boxes are both checked, click ok, click next, skip the email signup stuffs,and finish.
After the software is installed the phone should boot back up
Posted on Jul 13, 2009
fleshgear
Avinash Raj
  • 541 Answers
SOURCE: reload software 513 error
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps:
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK.
8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Posted on Aug 10, 2009
Anonymous
SOURCE: Reload software 513 for blackberry storm
I'm not too sure if all your data will still be there. But you can fix this yourself. You should be able to reload the device software with the Blackberry Manager.
Posted on Sep 04, 2009
David
  • 143 Answers
SOURCE: my blackberry pearl says reload software 513 how
The software will have to be reinstalled. You must download Blackberry desktop manager as well as the software from your phone carriers site for your model. After installing both of these open desktop manager and go to the application loader and update the software.
Posted on Dec 04, 2009
Reload sofware 513
Need to update software on your phone . For do that you can use Descktop Software (available on www.us.blackberry.com ) or just download and install on PC latest OS for your device ( search www.osforblackberry.com ) , delete vendor.xml from C:\\program files\common files\research in motion\apploader and run Loader.exe from same folder. Follow the step by step instructions of programm and update your smartphone .
Oct 13, 2013 | RIM BlackBerry Curve 8520 Smartphone
WHITE SCREEN RELOAD 513
Reload 513 appears when you have entered wrong password from some specified number of time.Due to this the phone wipes of the data fully.Now you need to reinstall the software.
Go to below website and this will show how to update the software
Thank You
Nov 29, 2010 | Cell Phones
Reload software : 513 comes with my blackberry 8520 curve what can i do
i'd attempted 10 times USB pwd, and now my phone s/w was all whipped off. msg on screen is reload software 513, plz help. i'd just got my Curve 8520 3 days ago...
May 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
My blackberry keeps saying download software 513
my blackberry says reload software 513 what site can i go on to fix my phone
Feb 20, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Everything deleted off my phone. i need to reload software :530
why yes they did take my phone and i got it back from them and it said reload sofware 513
Oct 05, 2009 | RIM BlackBerry Storm 9530 Smartphone
Aug 29, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to reload software 513?
I have a blackberry curve that drove me crazy because the application loader didnt work with mine either but here is what I tried and it worked for mine so hopefully it will work for yours. First, go to the blackberry.com website and click on software. Then click on device software. Select the version that is compatible with your phone. Be sure that your phone is connected to the computer with the USB cord that is came with. Then click download and follow the instructions from there. This should reload the software on your phone.
Jul 20, 2009 | RIM BlackBerry Storm 9530 Smartphone
My phone shows reload software 513 !
Full flash is required for your phone.you can flash it using desktop manager and you can download firmware here.http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Or you can contact w/ me if you need some help....,,my YM:[email protected]
Jul 20, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Need to reload software 513 blackberry
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
Mar 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry? Curve 8330 Cellular Phone Logo
960 people viewed this question
Top RIM Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Marvin
Marvin
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
