If the oil plug bolt is leaking you need a new aluminum sealing washer. There are no oil weep holes in the front of the motor. Is it the weep hole under the water pump? You probably have a bad water pump seal or a bad oil seal on the water pump shaft. Buy a new water pump and the K&L water pump gasket kit. The K&L gasket kit comes with all the gaskets, seals, and washers necessary to do the water pump replacement for a fraction of the cost of the OEM Honda individual gaskets, seals, and washers.
