Question about Keurig 5048 My K-Cup Reuseable Coffee Filter
When using MY K-Cup reuseable coffee filter, the coffee comes out the drip hole plus water comes out of the bottom front of the K-Cup Portion Pack Assembly Housing splashing down onto the counter. I made sure I had the filter cup closed tightly but that didn't help. I have tried 2 different ones thinking one may have been faulty but the result was the same.
Posted by lucy11349 on
Anonymous
I googled this problem for 3 days. I was reluctant to try anything that would screw up my machine, as I have been very happy with it, except for the re-usable filter performance.
I wiggled the o-ring washer around top sharp thingie by maybe 1/8 inch and that fixed it. K-cups are running normal as well.
Posted on Feb 24, 2011
2answers
Why is there more water in drip tray than coffee in cup?
Leak...... so... roast your own organic coffee (one cup 8 oz beans) in a 2qt pan 4" tall &6" wide with cool plastic handles not metal(dedicated pan due to it will turn black with use Farberware is good)with copper bottom and good lid. (shake pan on near high heat and look for dark brown color med to city roast) shake and look ...shake and look.... shake hard (hold the lid on tight!)so the beans flip up to the top of lid and really fall back down into the bottom all mixed so to cook evenly. It takes about 12 minutes start with lower 1/2 heat until green beans are beige color, then turn up heat to near highest flame. Some add a little butter or cocoanut oil in coffee cup. see on youtube and pour over filter 190 degree water. Get a V shaped funnel with handle that fits your cup & with holes in it to place the filter & fill with med grind coffee, 4 TBS & 1.5 cups water.
Coffee Shop coffee taste like bitter dishwater.
tip
Keurig Reuseable fiter's
Some of you get coffee ground in your coffee.
If you are using the MY K-CUP Reusable Coffee Filter, please make sure that you are using a course-drip. You should only fill the mesh basket to the bottom of the brown band, which is approximately 2.5 tbs.
The coffee grounds are dry after the cup is brewed. It does not taste like fresh brewed coffee.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thin wire to unclog it.
2helpful
3answers
I need a new replacement k-cup portion pack and filter assembly
replacement parts are hard to come by but the portion unit can be bought on amazon.
My filter was metal, so I'm not sure about something cracking...
ebay has many people selling broken units... good for parts...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
12helpful
Leaking water when using my k cup
Long story short, it will leak from under the screw cap (rarely) and from the rubber ring around the puncture pin. The grounds clog the metal filter and creates pressure that escapes from under that rubber ring. I cut a thin styrofoam plate to fit under the screw cap. It's really snug for the first few times, then it will loosen up. Second is to tighten the seal between the top of the 'my cup' and that rubber seal. I used 2 styrofoam rings that sit between the 'my cup' and the hard plastic it sits on when you fit it in the hole. It bring the cup like 1/8 inch higher to the pin and increases that seal. I made many cups after that and it has never leaked. I'm looking for a good rubber ring to fit around the 'my cup' to replace the rings for the seat.
29helpful
2answers
K-Cups disappointing
I had same problem and called Keurig. They advised me that the gasket in the upper portion, where the top needle is needs to be brought down about half way, almost even with the bottom of the top needle. Be careful not to poke yourself. I brewed a cup with the resuable filter assembly and it worked great. It should stay in that position until you use an actual k-cup. When using it will push the gasket back up, as it needs pressure to puncture the hole. To go back to the resuable filter, you will need to lower the gasket again. She advised me that they are working on a fix for this issue and will notify you of any replacement parts, as long as they have your current contact info.
7helpful
2answers
1. After brewing a cup of coffee, when the grinds are emptying, a stream of coffee and grinds drains into the Drip Tray from the valve(?) in the rear right of the Drip Tray. We have gone into program mode...
HI
Excess water into the drip tray is an indication that you don't have enough coffee going into the brew unit. There is a lever on the top of the door that has a + on one side and a - to the front. Push the lever back to the full plus, then pull it forward 1 click. Try that.
Water into the drip tray is normal in small amounts. This is the release of pressure after brewing, like the 3 way valve on commercial machines
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Pierre Laplante
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
