Hi, W/D here.
Kwikset has basically two styles of cover plates.
If you are on the locking side of the door and facing the knob you'll either see two screw heads (one on either side of the knob), or you see only the cover plate.
It sounds like you have the cover plate type. Here's how to get to the screws:
1. Feel the underside of the knob, and you'll feel a slot with a tab sticking through it.
2. With a fine bladed screwdriver, press the tab up into the slot, and pull the knob towards you.
3. With the door knob off, look around the edge of the trim ring for a screw driver slot. Insert the screw driver and gently pry the trim ring up.
4. You're there!
5. Re-assembly is in the reverse order. When you go to put the knob back on, you'll probably have to use the screw driver to push in the tab as you slide the knob back on.
Best regards, --W/D--
Fig. Expedition - Trim Panel Screws shown
Fig. Navigator - Trim Panel Screws shown
