SOURCE: problem with a disk read error
then remove ur hard disk,ram,processor and keep it again there may be chance to recover
SOURCE: NTRL is compressed Press Ctrl+Alt+Del to restart
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Please rate this fixya
SOURCE: NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
SOURCE: ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged:
Ntldr
Ntdetect.com
Boot.ini
To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current
loadTOCNode(3, 'summary');
Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer
Method 2: Use the Recovery Console
Ntdetect.com
Boot.ini
Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base:
301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
SOURCE: bootmgr is compressed and press ctri+alt+del to restart
Hello ajay1 8 83
You need run SFC /SCANNOW
Read this first for more understanding http://support.microsoft.com/kb/936212/
Try booting to your Vista installation CD. Choose Repair. Select your operating system, should bethe only one. It will repair the BOOTMGR.
