Question about Hitachi 1TB External USB 2.0 Hard Drive
The hitachi external hard drive was accidently unplugged when I was copying files on it. It now makes several beeping noises and clicking noises when plugged in and is not recognized by my computer.
Posted by tactful_demo on
Igor Mateski
  • 277 Answers
It sounds as your hard drive has a logical failure. To remedy this download the EASEUS Partition Manager Free, and run a partition recovery or partition repair. Hopefully, the unplug of the hard drive did not cause any mechanical defects and you will be able to fix the logical/software issue with Easeus.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Posted on Jan 31, 2011
My Hitatchi 250GB External Harddrive is not working at all when plugged in to any computer I own/use It makes soft beeping sounds for several minutes and then becomes silent The lights are on, showing
take the hard drive to a computer repair shop but from your description , it may be dead
if it is a disc type hard drive , then continually moving it around is not good for the delicate workings
if it is dead , replace it with a solid state hard drive which has no moving parts and is a lot more robust
May 05, 2017 | Hitachi SimpleDrive Mini 250GB USB 20...
How to transfer my life studio from one computer to another
Connect the external hard drive to the host computer.
This connection is most commonly made with a USB-style connector.
However, eSATA connectors are becoming more prevalent in the general computing market.
Plug the external hard drive into an electrical power source.
Navigate to the external hard drive listing under the "My Computer" window.
This is opened by double-clicking the "Computer" or "My Computer" desktop icon.
Double-click the external hard drive drive icon listing and navigate to the files to be copied using the provided navigation window.
Right-click the files to be transferred and select the "Copy" heading from the context menu.
Navigate to the destination folder on the host computers hard drive using the same navigation window.
Right-click within the folder and select the "Paste" option.
This begins the process of transferring the files to the computers hard drive.
This process takes several minutes to several hours, depending on the size of the files and the speeds of the hard drives.
A progress bar will appear to keep the user informed of the process completion status.
hope this helps
Jul 16, 2012 | Hitachi LifeStudio HLSDBUB10001BBB 1 TB...
How to transfer files from external hard drive to computer?
Connect the external hard drive to your computer using a USB cable. When you have done that, go to 'my computer', click open it. You would see your hard drive(C:\ ), and you would also see the external hard drive. Click open the external, go to the location of the files on your external, ie, they might be in a folder, right click the one you want to transfer, select copy, go to 'my documents' on yor pc, and paste.
If what you are copiying is quite many, select the first, then while holding down the control key, select the others, while still holding down CTRl, right click and select copy. Then paste in 'my documents'.
Hope this was helpful?
Have a nice day.
Jul 02, 2011 | Hitachi Computers & Internet
My external hard drive continuously beeps and makes a clicking noise. Also, no computer is able to recognize this external hard drive.
The spinning mechanism on the HDD is failing meaning it can't read data of the platans. Unfortunately you need to buy a new one as this one can't be repaired.
Dec 29, 2010 | Hitachi Computers & Internet
Hard disk not recognised
When a hard drive makes a clicking noise, it is faulty. The clicking noise is the heads swinging back and forth. This hard drive is dead and the data is lost. If you desperately need to recover your data, there are companies that can recover and copy your data from faulty hard drives BUT it will cost you an arm and a leg for their services.
May 15, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
Hitachi easy drive 1tb problem
I have a 640 GB easy drive. It hit the floor and now when I turn it on, all I get is beeps and hear movement in the harddrive but it does not work
Jul 09, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi External Hard Drive (500GB) Beeping sound
Probably not. You can try putting it in the freezer overnight (in a bag please, don't get moisture in it) but most likely if you must have the files back it will take professional help.
Jan 30, 2009 | Hitachi 500GB External USB 2.0 Hard Drive
Hitachi 1TB External USB 2.0 Hard Drive Logo
469 people viewed this question
Top Hitachi Computers & Internet Experts
Marvin
Marvin
Davit Mamyan
Davit Mamyan
Michael Thomas
Michael Thomas
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
