Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
SOURCE: Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
SOURCE: Glasses on upper rack getting food residue during cycle
is there anything blocking the spray or plugged in the spray arms check that
SOURCE: Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
SOURCE: model gu2700xtss1, upper rack not clean at all,
I am here for the exact same reason. Mine is less than 3 months old. This may be a recall item. I bought, and paid more for a kitchen aide for the name and reputation.....Where can I find the model number?
SOURCE: Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming
the top spray arms are clear of debris, remove the lower spray arm to
access the wash motor. Remove the 4 torx screws and the filter
(accumulator assembly). Remove the torx screw and the inlet protector
that covers the chopper assembly. Make sure the chopper is not broken
(broken chopper will fill with debris and block water flow). While
holding the chopper blade, reach inside the "D" shaped opening on top
of the motor and spin the wheel/motor by hand in each direction to make
sure either the chopper gear or the motor gear that drives the chopper
is not broken. Replace the chopper if necessary (part # 8268383). If
the motor gear is broken, replace the sump and motor assembly (part #
8535150). Remove any debris from the sump area in the process.
You
don't have to shut the power off to the dishwasher because the door will be open, but if you feel more
comfortable, do so.
