I had a door doing the same thing. My issue was that one of the wires in the plastic track that folds up was damaged. Basically, as the plastic track folded up to where there was a cut in the wire, the copper inside the plastic insulation pulled apart. Once you were past that point in the wire (where the door stops), the copper came back together and the door operated again.
Testimonial: "Sounds like a good place to start. Makes sense to me. Thanks."
I know that on the town and country van which is similar to yours has a tsb technical service bulliten out for this problem I believe it also applicable in your case. Check with dealer hope this helps
