Cell Phones Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What's the passkey for my bluetooth ? Than you !
Anonymous
Level 3:
  • Master 943 Answers
  • Posted on Jan 30, 2011
Anonymous
Master
Level 3:
Answers
943
Questions
0
Helped
163216
Points
2880
If you are looking for the passkey for your bluetooth headset, by default, it is usually 12345,1234.0000 or 00000.
If you need the passkey for your phone's bluetooth connection, you have to set this one by yourself. There is no default passkey for it.
When you want to pair with another phone, you enter the same key as you entered on your phone on the phone you want to pair with.
Hope this helped you? Please comment for more information
How can I reset my bluetooth password to my Dixon DN3238M3 receiver?
Where do I input the Bluetooth Passkey
  1. Touch Apps . Touch Settings.
  2. Turn Bluetooth on . ...
  3. Touch Bluetooth to scan for available Bluetooth devices (make sure your device is in pairing mode).
  4. Touch the Bluetooth device to select it.
  5. Enter the passkey or pair code: 0000 or 1234.
  6. Touch the device name again to connect to it if it doesn't connect automatically.
https://forums.republicwireless.com/t/where-do-i-input-the-bluetooth-passkey/3788/2
What is a Bluetooth passkey?
When you pair a bluetooth device, a passkey is required for pairing. Most bluetooth headsets and handsfree devices use the passkey of 0000 but for other things, a longer passkey of 6 or more random digits is usually generated by the pairing device and required to be entered or verified on the device that is being paired.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Bluetooth cant searching another device? what i should did for that?
Depending on your computer and any bluetooth devices make sure both have bluetooth are either turned on or made bluetooth discoverable
Bluetooth Pairing
Bluetooth pairing is necessary whenever two Bluetooth devices connect to each other to share resources.
A trusted relationship is established between the devices using a numerical password, commonly referred to as a passkey.
Depending on how often one Bluetooth device connects to another, the user might opt to have the passkey saved for future connection attempts or prompt to enter the passkey each time the devices request communication with each other.
Bluetooth Pairing Service
In most cases, Bluetooth devices are paired only once, and the details of the relationship are saved for later connections.
The pairing service, an integral component of all Bluetooth devices, is responsible for maintaining a list of devices that have made successful connections in the past.
It is essentially a passkey manager remembers the specific details for other trusted Bluetooth devices.
If a user has a reason not to allow automatic connections for specific devices, the Bluetooth pairing service will not store passkey details.
Preparing to Pair Because Bluetooth is a standardized-communication method, making trusted connections between Bluetooth devices is a straight-forward and simple process.
Before attempting to pair two Bluetooth devices for the first time, it is recommended to have both devices fully charged, turned on and Bluetooth enabled.
At least one of the devices must be set to discoverable mode, which means for a short period, the device will be announcing its presence to other devices within its range.
Pairing Bluetooth Devices
Have the second device search for other Bluetooth devices.
There are many types of devices on the market and just as many ways to put your device into discoverable or searching modes.
It is recommended you view the documentation for your specific devices to determine how to enter these modes.
Within 30 seconds, you should see the devices have found each other and a prompt to enter a passkey will be presented.
Bluetooth Pairing Passkey
The passkey is a four-digit number you supply at the time you are establishing your trusted relationship between devices.
If a specific passkey is set by the manufacturer, you can try "0000," or you might have to find the passkey in your device's documentation and enter that instead.
After you enter a passkey, the other device might prompt you to enter the passkey you entered. When the passkey is verified on the other device, the two have been paired.
The Bluetooth device and passkey information are stored using the pairing service so future pairing attempts do not have to be made unless desired as a security precaution.
Bluetooth software
You may wish to check out Bluetooth Command Line Tools a set of console utilities designed to work with Microsoft bluetooth stack.
Other Bluetooth resources
Visit our free premoderated Directory of Bluetooth Resources.
3helpful
My phone is asking for a passkey to connect bluetooth.what is the passkey for the motorolla H680
For security reasons, most Bluetooth enabled devices require you to use a passkey.
Note: Motorola handsets and accessories will use the following default passkeys: 0000 or 1234.
2helpful
2answers
Need a passkey for samsung omnia
hi, default passkey is 0000. Enter this passkey in the asus notebook when it asks for passkey.
Both the passkey should be same to enable file transfer through bluetooth.
3helpful
Logitech dinovo bluetooth keyboard passkey issue
You entrer your own passkey after hitting the connect button on the KB.
1helpful
2answers
Need Bluetooth passkey
a passkey is just a normal inserted between two bluetooth devices to connect them securely.
Let it four times 0000 as your passkey
1helpful
3answers
Bluetooth
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(Do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace key.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructions.
Hope this helps. Bud
8helpful
4answers
Passkey
The passkey for Motorolla bluetooths is 0000
Bluetooth
Click NEXT.
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
Finish and follow any on screen instructiond.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
