Under the drum on the right hand side. To get to it you will need to remove the top panel. UNPLUG it. take out the 4 screws that hold the control panel in place. Take out the three screws that hold the Main control board( on the lefthand side). Unhook the control board connectors from the main control board. Remove the control panel. Take off the 2 bottom screws inside the door, take off the 4 screws that hold the front cover plate. Take off front the front cover. Take off the 5 screws that hols the drum plate. Remove it. Remove the belt, and the metal bracket on top. Take out the drum and you will be able to access the element.
