SOURCE: Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
SOURCE: my acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
SOURCE: acer d2d problem
this is a quick fix. you need to find two files one called MBRwrWin.exe and the other file called RTMBR2.bin
copy MBRwrWin.exe to the root C:\
copy RTMBR2.bin to the root C:\
then from and command prompt just type in the following..... MBRwrWin.exe install RTMBR2.bin
press enter and your done... this will fix all d2d erorr but one.... this will not fix the type mismatch error... then power down machine and at start up use the keys... alt + f10 to enter recovery...
thats it... if this helped ya... let me know...
[email protected]
good luck and some kick back would be nice...
SOURCE: acer aspire 5920 series wont load past windows loading bar
OMG ... i was completley distraught. i bought my ACER ASPIRE LAPTOP 6months ago when i was trveling in italy ,im in austarlia. I use it torun my online game ; » www.themafiawarz.eu - and has all my files.
When i got the black screen o death i first am here to the boards finding nothing i was further distraught..
I AM HAPPY TO TELL YOU MY FRIENDS, that i am typing this on my lil baby
Heres what you do....
* you need usb disk drive
* a second computer with internet access (can be work cafe friends place)
* a file you can download from acer or search yourself called ZGIA32.zip
Formatyour drive in fat (*note i tried fat as directed in a number of manualsthough then tried fat32 and it worked then though suggest you try fatfirst *shrug)
open zip file and copy 3309.fd and the fla.exe to the usb stick
rename 3309.fd to ZGIA32.fd
Turn off your laptop making sure that both battery and power supply is plugged in and attach the usb stik/drive.
holddown FN and ESC keys and press the power button, continue to fold FNand ESC keys for 7-10 secs then release - at this point the power lightshould be blinking and you should still have the black screen of death.
press the power button once while its blinking - this will initiate a bios update * DO NOT PUSH ANYTHING AFTER THIS
After 2 mins the aspire should reboot itself , wait for about 7mins if it dosent before rebooting manually
Took me three attempts as i just wasent doing something right though TA DA!!!!!
and i still have my files. yeah team take this and run, hope you havent spent money yet
SOURCE: Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
