SOURCE: Sony DCR-TRV 140E
Yes got to sony
http://support.sony-europe.com/dime/camcorders/camcorders.aspx?site=odw_en_GB
pick your camera at the bottom, get the USB drivers and that should do. Programs it will work with include Pinnacle Studio etc
SOURCE: i have dcr trv 285e
here is the link for u to download ur drivers and softwares
http://support.sony-europe.com/DIME/camcorders/D8/D8.aspx?site=odw_en_GB&m=DCR-TRV285E
kindly rate me FIXYA if i have fixed ur problem
SOURCE: UNABLE TO TRANSFER VIDEO FROM SONY HANDYCAM DCR TRV TO MY LAPTOP
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This
Camcorder does not support USB streaming with the VISTA Operating
System. Use an i.LINK cable to transfer the video to the Computer. The
i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a
black D shaped connector with 4 or 6 pins. The type of cable to be used
will depend on the i.LINK port of your Computer. The Sony Camcorder
will have the 4 pin i.LINK cable and if the computer has the 6 pin
i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE:
As the Camcorder does not support USB streaming with Vista, it is not
required to use any Sony Device Driver to transfer the video to the
Computer. You do not require any Drivers or Software from Sony to
transfer the video from the Camcorder to the Computer using the
i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!
SOURCE: how can i transfer videos from DCR-TRV 460E TOCOMPUTER
It is very simple. Install a Firewire (IEEE1394) card in PCI slot (if you don't have any video capture card) and connect DCR460E camcorder to PC through iLink cable. You need a video editing software like Ulead Video studio, Pinnacle studio or any other to be installed in your PC. Then go to capture mode of that programme and capture transfer video to PC hard disk. Windows movie maker is also do the same. For editing and better special effects you should use hihger versions of ulead or pinnacle. Thank you.
Gautam Kumar Mandal,
Additional Chief Industrial Engineer,
Durgapur Steel Plant,
Steel Authority of India Limited (SAIL).
SOURCE: Windows 7 does not recognise imagemixer 1.5 for my
Yes its not compatible (with windows 7 and vista)
Please upgrade to Picture Motion Browser Software version 4.3.02
Please download it from following link:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4753&SMB=YES
Bingo !!! problem solved
